Hallo,
I'm looking for the same, color index remapping to RGB. Is there already a solution?
Thnx
https://communities.bentley.com/products/microstation/f/microstation-forum/126038/colors-conversions/
Andrew Bell said:Split this off from the original discussion as this appears to be a new issue.https://communities.bentley.com/products/microstation/f/microstation-forum/126038/colors-conversions/576630#576630
that link doesnt work for me .. page not found...
Lorys
Thanks Lorys, I'll fix that.
Updated: https://communities.bentley.com/products/microstation/f/microstation-forum/126038/colors-conversions/
PH said: If I use the same csv file in V8i SS10 on the same dgn, color is set to ByLevel
Are you saying that MicroStation V8i works the way you want, but MicroStation CONNECT behaves differently?
PH said:There are far too many levels to store them in a dgnlib
How many levels is 'too many'? A DGNLib is just another DGN file, so why is it OK to create those levels in the active DGN file but not in an attached DGNLib? What symptoms does MicroStation show when there are too many levels in a DGNLib?
PH said:... they have to be created on the fly by an application
Are you the owner of that app? Can you request a modification if required?
