The index distance, is function of the previous accudraw distance that was made. So if I drew (or offset …) a line 52.5633 previously. Next time I place a line, or offset etc, it remembers that 52.5633 distance, which is handy. I would like to make a bunch of keyins with 5 different commonly used distances in my drawing. Is there a way of doing that with a keyin? Or is the only way to generate a Index locked distance is by actually drawing something first? thanks
v8i select series 3
Microstation
Hi Abel,
Abel Vlad said:I would like to make a bunch of keyins with 5 different commonly used distances in my drawing. Is there a way of doing that with a keyin?
You can put your values inside function keys with this:
dx=value
example:
dx=.20
Then select your element and use the command copy (or move) then press the key-in that you create.
Others that you can put on different function keys are:
dx=-value
dx=,value
dx=,-value
José
