Hello Everyone,
I have a problem with MS V8i Select series 4.
I can't resize the docked tasks window beacuse it goes over the two monitors as you can see in the attached image. I can't click the X icon or the pin Icon cause they're out of the monitor's size.
Can anyone Help me?
Andrea
Hi Andrea,
andrea baldissin said:I can't resize the docked tasks window beacuse it goes over the two monitors as you can see in the attached image. I can't click the X icon or the pin Icon cause they're out of the monitor's size.
Go to Workspace \ Preferences \ Task Navigation \ Presentation:
And change to Tool Box option, click OK.
Then go there again and change to Dialog.
It should default back to the original size.
At last resort you could restore defaults will probably resolve this, but unfortunatley you'll have to configure all the others things that you probably made.
Please give a verified answer if this resolves your issue.
Thanks & regards.
José
Answer Verified By: andrea baldissin
Thanks a lot Jose for your quick answer!
It helped me only to unpin but it haven't resized the toolbar when I put it back to dialog.
At the end I will proceed to restore default as you suggested
Thanks again
