Hi, I cannot find element lock in MS Connect. It used to be under Edit/Lock (V8i). Thanks for any tips, Peter
Ctrl + L will lock an element.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Also, if you go to the Drawing workflow on the Home tab under Selection there are icons for Lock & Unlock
In addition you can use the Properties dialog ( Drawing > Home > Primary > Properties ) 'Extended' section to lock/unlock selected element(s)
Thanks. And what's the shortcut for unlock please?
Hi Peter,
Peter B said:And what's the shortcut for unlock please?
MicroStation ribbon tells you ;-)
Jan
