If we try to create a Solid with Extrude from a closed element from a reference with Keep Original turn on, we get No elements selected in Message Center.
It's exacly the same situation for surfaces.
This doesn't happen in SS3.
This happens because Parametric is turn on. This is WAD or a BUG?
I believe we should be able to extrude from reference as always if we have Parametric turn on or off.
I've seen similar behaviour on other commands in CE, ie commands that identifies elements i references does not work. One example is Point At Distance Along. If the path element is in a reference you get the error "Element no valid for tool".
This has been reported,
/Krister
Owner consultant at Surell Consulting AB
Hello Jose,
Yes, this is a known issue and we have a defect to track this (Defect-1005918) and similar other issues with Reference Geometry that cannot be used conveniently with Parametric Solid. We will try our best to address those in post U14 release.
Best Regards,
Dinesh
