If we RMB [ Right mouse button] on top of Explorer \ File \ Environment Setups and Render Setups we see this:
Which is very strange as we can't isolate and zoom this things.
I bet we should see something like Display Styles for the Environment and Render Setups:
Thankyou for reporting, we will have this reviewed / filed Defect 1087627
Carl Myhill
Technical Support Engineer
Bentley Systems
Hi Carl,
You guys removed Zoom, Isolate, Clear Isolate which is right. But Activate, Copy, Update from Library, Rename and Delete weren't placed?
José
Agreed, we will have this reviewed Enhancement 1131638, thanks for reporting.
