Can somebody ilustrate the process from creating the icon or bmp to haivng the tool in a Ribbon with the assigned function?
I'm writing as having created both bmp and ico files, and having imported these to MS Connect via the settings-customitze dialog, it turns that on applying the bmp or icon file to the tool, Microstation returns a "no item has been selected", and there is not icon shown for the tool.
Have you imported the icon into a .dgnlib that is located in the MS_GUIDGNLIBLIST?
Following on from Bruce's suggestion the following Blog series may be of help illustrating the process https://communities.bentley.com/products/microstation/b/microstation_blog/posts/customization-blog-series-customizing-the-ribbon---blog-3-of-4
Please also advise on the version being used and steps taken to date if further assistance from others is required.
Carl Myhill
Technical Support Engineer
Bentley Systems
Hi Bruce, I made it now and the icons I produced are now working in a customized ribbon. Thanks.
Thanks for the advice. I will note on version in future questions.
