I am working remotely from home and recently acquired a second screen. Microstation windows do not recognize the second screen. What do I have to do to get Microstation to recognize both screens? I am using Microstation v8.11.9.829.
Thanks in advance.
Hi Brent,
Brent Lowe said:What do I have to do to get Microstation to recognize both screens?
Please check if you have turned on Open Two Application Windows inside Workspace \ Preferences:
Reagrds
José
And after that, when you reopen MicroStation, make sure that you move the second window to your other screen. Sometimes they both open on the same screen, and I have to move them each around to get it to look right.
MaryB
This works best for me without opening 2 application windows. If your second monitor works correctly in Windows, it should be fine in Microstation.
Maybe you can elaborate on-
Brent Lowe said:Microstation windows do not recognize the second screen
Right-click on your desktop and choose "Display."Choose the monitor you want to use as your primary display from the list.Check the box next to "Make this my primary display." The other monitor will automatically switch to secondary mode.When you're done, click [Apply].
