I have been experimenting with 3D parametrics and was wondering if it is possible to create a solid and then add constraints and variables to the faces and edges of that solid? The current process of drawing in 2D and extruding elements seems a little simplistic and doesn't allow for more complex shapes. It also seems to create a more complex shape with this method that you may have to make multiple extruded solids and constrain them together. By doing this you have multiple solids instead of one.My goal is to have a single solid that is parametric.
Don Horton said:I have been experimenting
In which version (e.g. v10.x.y.z) of MicroStation?
Mainly Connect either stand alone or within OBM or ORD. I also have V8i.
Which version of Connect (10.xx.xx.xx)? There have been several iterations, and there could be differences in functionality between each.
MaryB
OBM 10.08.00.60
ORD 10.07.03.18
Microstation ss3 08.11.09.536
Microstation ss4 08.11.09.832
Mainly looking inside the OBM,
