recently I returned to MicroStation V8i (SELECTseries 10), specifically it's build 08.11.09.919.
I discovered, when the first design file is opened (any workspace), several messages "Unknown key-in or command" are displayed in Message Center.
Because it's the same for two different installations on different computers, I guess it not caused by customization (the same behavior also for Untitled / Untitled and Exampels workspaces), but by something wrong in initial MicroStation startup configuration.
Did somebody see the same issue? Probably not critical, but annoying for sure...
With regards,
Jan
Morning Jan
I reported this to Bentley a few months back and a Defect was was raised
Defect 1042848 [Regression][From SS4] When starting MicroStation SS10 Message center holds 10 lines with the text Unknown key-in or command
HTH
Ian
Answer Verified By: Jan Šlegr
This is a defect as pointed out above, It does not cause any problems, Micorstation is sending a command to itself for tracking purposes but the command it sent was removed.
Paul
