I'm new to the concept of Remote Desktop - but as I have a HP z640 and zBook, thought I should try this out.
HP's instructions say "The sender and receiver must be on the same network for a Remote Boost connection to be established between them."
Does this mean it only works within one location (ie. within my home-office network)? Can I not use it remotely through the internet?
Max
Hello Max,
this is a question for your local Network-admin.
But normally this is solved by an VPN - tunnel. So you could be in the same Network, but also be at some different Location at the same time.
Mit freundlichen Grüßen / Best regards Volker Hüfner
| AB_DATE Engineering Software | ab-date.de |
