another user working the same file turned off some elements using the 'turn off by element' command, causing those elements not to be displayed. the level manager shows the respective levels to 'used' but do not display. i have researched a way to undo this process but only to come up to the conclusion that the only way to undo this is to use the 'view previous' command, this option is not an option since there has multiple saves before realizing this.
Is there another option around this?
thank you
Hi Justin
This is always an issue where multiple users edit a DGN file. What i would suggest you do it to create a SAVED View. This will recall the view setup if anyone updates it it. It does however, require management, ie if you make a change then you need to update the saved view.
Ian
