This drives me nuts as I always have to go the "interactive" dialog
If I attach a reference the setting "cached" is default. The cached attachment gets this weird text display. Anyway the caching seems not to bring any benefits for simple drawings (?) - on the contrary...
Is there a setting to change that? In the preferences for references there is only a setting to switch on "Always in Cache" which is exactly the contrary of what I want to achieve.
If I choose to reference a file "identical" - as it should be mostty in my workflows - I always need to still go "interactive" through the attachment dialog.
At the same time I also would want to generally have the Drawing Border set to"(none)" - I cant find a preference setting for this as well.
(Sorry if i have the wording not quite right here - I am using a german interface and the last time I switched the language I had to completely reinstall as the german language option was completly lost... I do not want to through that again - I have work to do)
Hello Gerd, very good points that you mentioned there. I feel the same way. Until this day I have not found out in which situations the cached option seems to be working better. In contrary: The loading times are horrible and the reflection of changes is confusing because you have no direct control via a button, like the reload button for attachements. Also I have not found a use for the created drawing boundaries yet. To make it easier for non germans I added a picture of the attachment dialog in the english version. The setting you called "interactive" is called "dynamic" in the english version.
Currently using:
OpenPlant Modeler - Version: 10.09.00.74
[MicroStation - Version: 10.14.02.01]
I'm also confused and the feeling as that the behaviour has changed somewhere along the way. It now seems to be the default when 3D files are attached to 2D files.
You can, however, set the default by defining the following variable:
MS_REF_VISEDGE_ATTACH_STATE = Dynamic
Krister
Owner consultant at Surell Consulting AB
Answer Verified By: mlm
Krister Surell said:You can, however, set the default by defining the following variable: MS_REF_VISEDGE_ATTACH_STATE = Dynamic
This setting does not exist under the MS_REF_DEFAULTSETTINGS variable and could be added if desired by requesting an enhancement, but as mentioned by Krister there is a separate variable for this.
Regie
Thanks Florian, my take is that some of the settings are "remembered", at least while in the same session of microStation. Others are need to be always to be set again.
Hi Kirster, very good. Thanks for this. I guess I never would have guessed it under something "visedge"
