Hi, I am trying to apply the same level state (on/off) between two files using a saved view in OpenRoads Designer 2020R1 (which uses PowerPlatform V10.13.02.02). After importing the saved view to my second file and applying the view to a view with Levels option toggled on, level state doesn't change. If I try to apply the saved view in the first file (to test the levels state is saved) the level state changes as expected. I basically follow this guide:
https://communities.bentley.com/products/microstation/w/microstation__wiki/21546/apply-level-display-state-to-other-files
Do you know if this workflow is actually applicable to MicroStation Connect Edition?
Mariusz
Thank Chuck posting this information.
Mariusz, I have confirmed that this issue is fixed in MicroStation CONNECT Edition 15.(10.15.00.74)
Regie
Answer Verified By: Mariusz Heczko
Thanks Regie and Chuck for coming back with the good news.
OpenRoads Designer 2022 R1
