Would it be possible to select whether MicroStation should use one or two application windows at startup? I guess this is stored in prefs so here are some suggestions using different shortcuts. This would be great for all of us that frequently dock and undock the laptop.
Maybe setting MS_USERPREFSEED on the command line?
Is there some dedicated configuration variable?
Krister
Hi Krister,
Krister Surell said:Would it be possible to select whether MicroStation should use one or two application windows at startup?
No need for that, since Release 0 of Connect Edition back in 2015 as long you have two or more monitors selected in preferences [ Backstage \ Settings \ User \ Preferences \ Operation ], it automatically opens only one window if you don't connect more monitors.
This is a great addon for me and I bet for many other users.
Please follow this wiki for more help.
José
Answer Verified By: Krister Surell
I actually missed that. Thanks!
It would still be useful though since I sometimes would prefer to work with just one window even when I'm docked.
/Krister
Owner consultant at Surell Consulting AB
