MicroStation V8i: the Key-in syntax of "db="
Hi Experts,
I saw a documentation page of ACTIVE DATABASE like
http://www.mdlapps.com/microstation/ustnhelp2016.html
In my MicroStation V8i SS4, I also see a similar page in the help document.
For the "(DB=)" note beside the title: does it mean I can use "DB=" instead of "ACTIVE DATABASE" in the Key-in command to do the same task?
For example, if I input a command like "db=username/password@server" in some circumstance, it should also connect to an Oracle database. Am I right?
Thank you!
Sui
