Hi everyone hoping that all are doing fine inspite of the situation around us, just keep safe everyone.
Anyways, I would like to know if there is a way of returning the original state of a dimensions after it is being droped or exploded.
What happen is I've imported drawings from autocad format and in those drawing files all the dimensions are exploded and now our client requires all drawings in DGN format and they commented that they want all the dimensions to be in its original state which is a true/active dimensions and not just a bunch of text, lines and shapes.
Is there a way, a command or anything that i could use for this matter, because I've got alot of sheets to cover.
Hoping that someone could share if there is a way. Thank you.
Keep safe and stay at home everyone....
You have posted in the Communities Feedback forum, which is meant for discussions about the Community site itself. For product-related technical questions, you can get help in the related Product Community.Please let us know which Bentley product you are using and we can move your post to the correct forum.
Good day Ma'am, sorry if I made a mistake posting this question in a wrong forum, just wanted to ask for some help from the experts regarding may question as stated in the subject above. Anyways to answer your question I'm using Microstation V8i (SELECTseries4).
Hope you can direct me to the right forum for this matter.
Thank you and have a nice day.
Carl Nhelee Angcaya said: I've imported drawings from AutoCAD format and in those drawing files all the dimensions are exploded and now our client requires all drawings in DGN format and they commented that they want all the dimensions to be in its original state
Your clients should stop dreaming and move into the real world.
Here's an analogy: I give you a book to read. However, I first tore out all the pages and threw away the covers and index. On each page, I removed its page number. You will enjoy reading the book as soon as you have reassembled the pages in the correct order. That's a simpler task than your client has set you!
Objects that were exploded in AutoCAD have no memory of their origin — they don't 'know' that they were once part of a more complex object. It would be impossible using AutoCAD to recreate the dimensions from an unconnected assortment of lines and numbers. Yet your client expects you to use a different CAD tool to reassemble those dimensions in another file format?
Your only hope is to obtain the DWG files before the dimensions were exploded.
Yes you're correct Sir, actually before we start doing the changes that they want, we tried to defend our side that it would take time because we know that there is no way it could be done in a shortcuts. but sad to say they insist that they required the change so now i started re-dimension everything in microstation.
anyways thank you very much sir for the prompt response.
Regards and keep safe.
