Just tried to use the Dimension Element tool (via PM from Tasks) and get Dimension Element Constraint.Is this the same as Dimension Element?
Also note that this tool has different symbology/style than Dimension Linear and doesn't allow me to pick the Dimension style. Note the wrench icon is back.
Anyone?
Stuart
In CE14 when I use this tool , I get what I would expect.. Dimension Element and a normal dimension. What is it you are seeing?
I see what is shown in the screenshot above.The dimension toolbox shows 'Dimension Element' but I get 'Dimension Element Constraint'.
This is what I see, in both Ribbon and Task Navigation mode
Odd as I see 'Dimension Element Constraint' from Tasks but 'Dimension Element' from the ribbon. I guess that Bentley will have to let me know what the problem is. Note that I don't use the ribbon and keep in minimised.
