I have just tried to 'save as' a .dgn design model to .dwg and U14 ignores the above setting and turns on all levels in the .dwg file. It didn't dos this in U13 as far as I can remember and having just tested in doesn't do it in SS4. The SS4 conversion is what I should be getting.
U14
SS4
Hi Stuart,
Are you merging any reference attachments or retaining them during save process?
Regie
I'm merging.
I had your files that you previously shared with me and I was able to get the desired results by turning on the "Merged Displayed Level Only" setting.
I used this setting because the unwanted elements that were appearing in the DWG file were not on in DGN files before saving. These elements were included in a DWG that was attached to the original DGN file.
Reginald Wallace said:I had your files that you previously shared with me and I was able to get the desired results by turning on the "Merged Displayed Level Only" setting.
This was already set and greyed out! Why is it greyed out?
Question...What if I wanted to merge all the levels into the drawing (in case I needed that information down the road) but wanted to maintain the level display of the original. As in, what if I wanted to merge those levels into my drawing but I wanted them to merge with the display off/frozen?
I know that I have (in the past) run into issues with creating dwg files when level display was turned off by "View Display" because DWG has no such thing, but I seem to recall that Global Off/Freeze were respected. Has that changed in CONNECT?
MaryB
