Has the Tag Editor been completely discontinued?
After updating my Microstation CONNECT to Release 14 last night, I have discovered a problem today. Every time I attempt to use Tag Editor to update Tags, CONNECT Rel. 14 crashes to my desktop without any warning dialog boxes or anything else that I have noticed. I cannot recall ever having this prior to upgrading to CONNECT Rel. 14.
We have a cell library with a cell in it that is comprised of several tags. We insert that cell into our .dgn file and then fill out the tags with drawing title block information. I can no longer use the Tag Editor to change the Tags that are part of this cell. I am able to use Text Editor successfully. The Tag Cell itself was created two or three years ago, either in an earlier release of CONNECT or in Microstation V8i SS3, or maybe SS4.
I have attempted to work on the .dgn file on my local drive and a network drive with no success. I copied a drawing created one week earlier to my local drive and attempted to edit the title block Tags on that drawing with the Tag Editor. The Tag Editor dialog box came up, fill in with that drawings information. As soon as I left-clicked on one of the values, CONNECT Rel 14 gave me the spinning "wait" wheel for a second or two and crashed to my desktop. Text Editor worked without any problem on that drawing as well.
Windows 10.0.17763 Build 17763 , Installed RAM = 16.0 GB, Available Physical Memory = 9.8 GB, Available Virtual Memory = 12.0 GB Page File Space = 2.38 GB
KRolfs said:Has the Tag Editor been completely discontinued?
For sure not :-)
KRolfs said:Every time I attempt to use Tag Editor to update Tags
I tried Tag Editor with several design files and it works fine.
KRolfs said: I am able to use Text Editor successfully.
There is no relation between Text Editor and Tag Editor, they are different components and code.
KRolfs said: As soon as I left-clicked on one of the values, CONNECT Rel 14 gave me the spinning "wait" wheel for a second or two and crashed to my desktop.
It would be interesting to know whether MicroStation creates any exception log and memory dump, because it can help to identify what is wrong.
KRolfs said:After updating my Microstation CONNECT to Release 14 last night
Maybe your upf file (or any other file in user preferences) has been corrupted? Historically when MicroStation behaves weird, it's nearly always caused by upf file.
Can you try to reset your preferences? You can use RestoreDefaults parameter, or to delete upf (or the whole content) manually.
From recent posts my feeling is Update 14 is more sensitive about U13 upf files (or maybe U13 does something wrong), but I think it's often the only way how to return MicroStation back to normal mode. Unfortunately the cost is the preferences are lost (when no upf seed is used).
Jan
Labyrinth Technology | dev.notes() | cad.point
I moved my .UCF and .UPF files to a different directory and renamed them to .OLDxxx. I am still crashing to my desktop when I attempt to use the Tag Editor. I went to the directory specified in MS_TMP to try and look for exception logs but I couldn't recognize anything obvious. I sorted the "Log"' sub-folder by the most recent modified date.
Hi KRolfs,
This issue has recently been discovered and Defect 1093402 has been filed. Thank you for bringing this to our attention as well.
Regie
Sincerely, thank you for keeping me inform.
Hi Reginald,
for the confirmation of the bug.
I'd like to ask what is a description of the bug, because as I wrote, I tried (quite simple) tag edit and it works, so I guess there are some other conditions where the bug causes the crash.
With regards,
