Has the Tag Editor been completely discontinued?
After updating my Microstation CONNECT to Release 14 last night, I have discovered a problem today. Every time I attempt to use Tag Editor to update Tags, CONNECT Rel. 14 crashes to my desktop without any warning dialog boxes or anything else that I have noticed. I cannot recall ever having this prior to upgrading to CONNECT Rel. 14.
We have a cell library with a cell in it that is comprised of several tags. We insert that cell into our .dgn file and then fill out the tags with drawing title block information. I can no longer use the Tag Editor to change the Tags that are part of this cell. I am able to use Text Editor successfully. The Tag Cell itself was created two or three years ago, either in an earlier release of CONNECT or in Microstation V8i SS3, or maybe SS4.
I have attempted to work on the .dgn file on my local drive and a network drive with no success. I copied a drawing created one week earlier to my local drive and attempted to edit the title block Tags on that drawing with the Tag Editor. The Tag Editor dialog box came up, fill in with that drawings information. As soon as I left-clicked on one of the values, CONNECT Rel 14 gave me the spinning "wait" wheel for a second or two and crashed to my desktop. Text Editor worked without any problem on that drawing as well.
Windows 10.0.17763 Build 17763 , Installed RAM = 16.0 GB, Available Physical Memory = 9.8 GB, Available Virtual Memory = 12.0 GB Page File Space = 2.38 GB
Hi Jan,
The description of the defect was "Editing tags cause MicroStation CONNECT Edition Update 14 to crashes completely when we hover over the value column and tooltip wants to show the wanted values for a field."
This issue was reported last week through our Support channel and I was able to reproduce the issue with a sample file that I had created some time ago. It was not so much editing the tag as the crash occurred when hovering over the "Value" column in the Edit Tag interface.
Try the same operation on your end and see if the problem occurs. If it does not crash would you mind sharing one of your files so that I an have Development examine the differences in our files?
Regie
Jan,
Let me also add that the crash occurred when multiple rows were selected as well. Hovering over the first value field will not cause the crash it when hovering over additional ones.
Hi Regie,
my file (cell library with one title block cell + file with the cell placed) is attached.
I tried different tasks (hover over the dialog, edit different values etc.) and nothing happened.
So at least it should help to distinguish whether it's design file related (when my file will work) and installation dependent (when it will crash on your computer) ;-)
With regards,
Jan
with_title_block.zip
Labyrinth Technology | dev.notes() | cad.point
I opened your file and tried the same operation and did not get the crash.
I did notice that might file was dated from 9 years ago so the tags sets themselves might be much older. Were your tags created in your cell done in a version prior to MicroStation CE?
Reginald Wallace said:Were your tags created in your cell done in a version prior to MicroStation CE?
No, it's CE version.
I do not want to promise, but I can try to create the same data set, but using V8 2004 Edition (the oldest version I have installed ;-).
