I have been able to go to Element -> Cells and open the cell library before, but now it doesn't work. When I click on it, nothing opens up. I've tried using the cell selector and that works, but when I want to fill an area with a pattern I have to open up the cell library. I'm not sure why this happened all of a sudden. Does anyone know how to fix this?
Thank you!
Sang Yoon Kim said:I have been able to go to Element -> Cells
What version (e.g. v10.x.y.z) of MicroStation or other product are you using?
Is configuration variable MS_CELL defined correctly?
MS_CELL
That is, does MS_CELL point to one or more folders where your cell libraries are located?
This version is MicroStation V8i (SELECTseries 4) 08.11.09.832
I believe it does. I never changed anything in the configurations.
Search these boards for "missing dialog" and you should find several suggestions to relocate a missing dialog box. It's not unheard of for a dialog box to get "lost".
As a last resort, you could try deleting your UPF file. This will eliminate all your personal settings, but it also resets dialog box location back to the default.
MaryB
Answer Verified By: Sang Yoon Kim
Following may help https://communities.bentley.com/products/microstation/w/microstation__wiki/15899/dialog-toolbox-does-not-open-or-is-missing
Carl Myhill
Technical Support Engineer
Bentley Systems
Thank you so much! It was a lot simpler than I thought.
