A feature I use every now and again is the background map thru view attributes. I cannot get it to work with r14, any file. Anyone else had this issue, pretty sure it was working previously. I'm trying to use a street map (or aerial).
I assume this is the Background Map section that should be displaying at the bottom of the View Attributes dialog.
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v16/en/GUID-82AF9170-15B1-461B-BF12-46F1A05EF34A.html
It works for me (10.14.00.109).
The Help entry is misleading - reference to "Show Background Map Providers" - there is only one provider; Bing
Max
Andrew Bell said:I assume this is the Background Map sec
Yea that's the one. Apologies, it's working today.
(Why is my signature only showing sometimes in these posts? Where is the forum forum for these type issues?
I do notice that initial posts do not contain my signature - only my replies. Not sure why that is...
MaryB
Maybe the files are missing a coordinate system definition?
If there are no coordinate system attached to the file this information are not shown in View Attributes.
/Krister
Owner consultant at Surell Consulting AB
