I can't be sure, but you may want to search this forum for "DirectX" because I have seen some threads on various issues.
MaryB
Hi Mary,
I searched again for "DirectX" and "Nvidia" but did not find anything recent and reasonable.
Thanks anyway!
lucadirosa said:[CONNECT] [ 10.07.00.39 ]
This is quite old version. MicroStation CE Update 7 was released in November 2017, so about 2.5 years ago! The current version is Update 14 and it can be one from reasons why it's slow, because CE is debugged and optimized with every release (and especially Update 14 seems to be substantially faster).
lucadirosa said:Can't understand if this is related to:
It's hard to say without detail analysis. Unfortunately there is no official video benchmark available for MicroStation, so it's not simple task.
lucadirosa said:Anybody experienced similar issues or can give an advice?
As MaryB mentioned, different issues with DirectX support in Nvidia drivers were discussed in the past. My personal feeling is that even when Nvidia produce pretty good hardware, they focus too much to OpenGL support in their professional cards and DirectX has lower priority (because they treat DirectX as Windows gaming API only).
My recommendation is:
With regards,
Jan
Hi Jan,
thanks for your answer
I am waiting for advice from Nvidia support but I wanted to search in Microstation Community as well for some feedback.
Regarding the upgrade I would like to do it but I am threatened by Bentley licensing policy, which force me to update as well other software which I am not using any more but need to keep operative in order to access my older project files.
Will update this post if I get the solution from Nvidia.
Kind Regards,
Luca
