Moving Objects in Fence at two unknown angles
I need to move/stretch a portion of my drawing to make more room for other objects. Is there a command or way to move/stretch these items to an unknown distance or unknown angle? This is hard for me to explain so please be patient with me.
So say I had this drawing located above and I wanted to move/stretch to make more room for other items. I would then need to move/stretch it the west at an unknown angle to keep the pink line in  the fenced in area to the South and the West.
as shown above I moved it to the west (see blue arrows) and the pink line now is in the right angle but notice other parts are not in correct angle as seen below.
I would like to move all of this at once in both directions/angles at the same time. Is there a command or set of commands I am missing? I know this seems really easy but I can not seem to find a solution anywhere and could be I am not looking for the right terminology I don't know. I do know it would be a great help and time saver if someone can help me.
Thank you
  • what  I have  done  in the past is rotate the view along the pink line and fence stretch  with axis lock via accudraw. and turn off the cloud level also very careful with the fence to not cross over  but skirt  what not to change and enclose what needs change.. level names and turning on and off are very important with this kind of thing.. I use this method to change typical sections all the time  to make room for more features or modify similar plan to make a new  one.. I think would work for you if your careful placing the fence and wether or not  use clip or inside  fence... with the rotated view to the axis you want. as your unknown angle....
    Lorys
    click link to PM me
