Feature Manager Toolbox Empty
A little bit ago, I discovered the feature manager in microstation v8i. I found that it is a very useful tool however, I accidentally minimized it rather than closed it and now this is all it shows when I open it up. Any suggestions?
  • Restore default settings by adding “ustation.exe  –restoredefaults” to MicroStation shortcut and start it. Please remove –restoredefaults after the settings are restored.
    • Look for MicroStation shortcut on your desktop. If you don’t find it, create one.
    • Right click on properties
    • In the Target after ustation.exe add this string " –restoredefaults"
    e.g. " C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\ustation.exe" –restoredefaults
