June 2020, Copy & Paste From Excel & Word Documents (Windows 10 & Microsoft Office 365) Into MicroStation Connect Version 10.14.00.109.
We copy the spreadsheet or word doc "As-Is", then paste the image (format, text, lines, colors, borders, etc.) onto the drawing.
It has worked well for years, now, after update, it does not work at all ! ! !
Please advise / help - - I copy & paste many Excel Documents into my drawings.
Thank You
I can confirm i see the same issue it appears to paste the excel information as text. I tried paste special and was not able to reproduce the same quality of picture from excel that i'm used too.
It did let me paste the information into a table still, but without a means to auto correct the table size it's very clumsy and not a viable solution for production work.
So the question for Bentley is was this an intentional change and WAD or maybe the old way of doing things is built into a new tool i can't find?
-Grant
It will let you "Copy" then "Paste Special" via "Device Independent Bitmap To Design File" - - But that is a pain and poor quality printing - -
There was just the same discussion in the German forum.
You need to run the key-in mdl load olecntr. This loads the MDL routine needed. You can also change the config variable MS_DGNAPPS to the standard C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\MdlSys\Asneeded,olecntr.ma, so the routine gets loaded automatically.
Then the old behaviour is restored.
f.mandoki said:You need to run the key-in mdl load olecntr
Thanks to Sven Zigelski for publishing that tip.
But why is it necessary? Can someone at Bentley, perhaps Andrew Bell raise a Service Request to fix that broken tool?
Defect 1090927 has been filed, thanks for reporting.
Carl Myhill
Technical Support Engineer
Bentley Systems
