I had undocked my Model window and was moving it over to my other screen when it expanded and took up the entire window in MicroStation, hiding the options to undock/unpin/close/etc as the very top of the toolbar is hidden. I encountered this issue just last month but thankfully I had a second instance of MicroStation opened with the Model window opened and docked at the bottom. So when I closed the MicroStation application and reopened my file, everything went back to normal. But this time I don't have another file open so I'm pretty stuck. Any idea how I can get that top part of the toolbar to show up so I can move my Model window off to the side again? Thanks!
Good to hear you were able to resolve your issue. Another suggestion could be to reset your User Preference File and clean out any temp files.
https://communities.bentley.com/products/microstation/w/microstation__wiki/8978/how-to-reset-user-preferences-and-delete-microstation-s-temporary-files
Just to note as well that you should note which version of MicroStation you might be currently using.
https://communities.bentley.com/products/microstation/f/microstation-forum/87312/read-first-microstation-forum-best-practices
