I am not looking to plot linestyles, but to list if they are Physical, or if they have a scale factor applied, and possibly more.
Having to individually identify each one in the dialog box and use the interface to verify these types of settings is tedious and time consuming. So if anyone has come up with a better approach, I would love to try it out.
An old MDL from Ask Inga would document the linestyles in a file so you can visually see them. It might help.
Here is the link for the download of DOCLS_V8.ma :
https://communities.bentley.com/products/microstation/w/askinga/1106/document-your-custom-line-styles
Karl Todt said:An old MDL from Ask Inga would document the linestyles
Unfortunately, an MDL built for MicroStation V8 will not work with MicroStation CONNECT (CONNECT is 64-bit; V8 is 32-bit). The author, Miro Mates, has not been active here for many years, and is unlikely to port it to CONNECT.
I like BobPeterson's use of MicroStation CONNECT Reports. It eliminates the need for programming, using built-in features of MicroStation.
Lorys said:Sounds like a job for vbaMan!
BobPeterson has made vbaMan redundant in this case!
I agree Jon, the MDL is not for CONNECT Edition. CaddCop's posting was for "All Versions" so I hoped it would at least aid the V8i versions.
I still use it from time to time..
Lorys
