Is there a key-in for Rotate 2-points? I'm assigning them to function keys, and I can get it to rotate by angle (rotate original) and rotate 3 points (Rotate points) but I can not figure out how to get Rotate 2-points, which is probably my most used Rotate command.
Is it possible? Thanks!
What version (e.g. v10.x.y.z) of MicroStation are you using?
Tom Kelleher said:Is there a key-in for Rotate 2-points?
Key-in options are shown in MicroStation help but I don't see a command for rotate by 2 or 3 points.
Key-In: rotate icon;set item toolsettings rotatemethod=1
Key-in: rotate icon;set item toolsettings rotatemethod=2
For 2 points try "spin", "spin original" or "spin copy"
Matt Eiben
Matt's got this, Spin it is
Answer Verified By: Tom Kelleher
Matt for the winning shot!! Thanks Matt!!
