I use microstation ss4 and when i cutting a section using section call out I get unwanted lines. May I know how can we avoid this ? Is there a setting ?
looks like you have a hatch pattern template applied to those elements, if so remove it.
-Grant
HOW CAN I REMOVE THE HATCH PATTERN TEMPLATE ?
Assuming these are coming from an Element Template, you can remove the 'Template' assigned to the solid(s) by selecting them and using the 'Element Information' dialog ( Properties dialog ) removing the Template.
See also https://communities.bentley.com/products/microstation/w/microstation__wiki/10501/creating-an-element-template-with-a-custom-section-pattern
Carl Myhill
Technical Support Engineer
Bentley Systems
