Transparent elements in the microstation 3D model in section cut appears dark.
I have changed the transparency of the tube from 0 to 90 in the 3D model but when I cut the section some of the transparent elements still look dark in cached visible edges. I use microstation ss4. Can you please guide
  • Sorry for the delay in responding to your issue. Have you found a resolution to this yourself or do you still require assistance?
    Are these items displaying in grey possibly in a separate referenced design file? Maybe this referenced file has a different display style associated with it? Is it possible for you to supply an example design / referenced files for use to have a closer look.
    Andrew Bell
    Technical Support
    Bentley Systems
