Batch Convert Doesn't Merge Reference Files?
I think I am missing something, but will ask anyway...
We're running MicroStation SS10. We have a project with V8 DGN files stored in ProjectWise (PW). The client requires merged DGNs (i.e. no reference attachments). Appreciating the information that others have put up here regarding how to use the Batch Converter for this process, we created a new folder in PW for the merged files to be placed into, fired up Batch Converter, opened up the V8 Save options, made sure all references' were set to Merge, and chose two files to convert as a test. We then processed the files. New files did indeed get created in the PW folder.
However, two odd things occurred:
1. The time each takes to convert is listed as 0.0 seconds. The status column indicates "Already Converted".
2. When I open one of the newly converted files, nothing is merged. The resulting file still has all the references attached, as though we had merely copied the file over to a new folder.
I tried this twice: once with a fie I was already in, and once more with a file I was not in.
What am I missing???
  • Use Batch Process rather than Batch Convert. Your key-in would be "reference merge <ref file name>".
    You would add this line for every reference file you want merged. I think if you want all references merged you can just use "merge reference" or "merge reference all"
    If there are references that you want to detach after you merge the required references just use "reference detach all"
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
  • how to use the Batch Converter for this process,
    This always works for me but without projectwise and V8iss4 and even better when I use option convert to DWG ...it must be a projectwise thing to change  to allow mstn to create the new files and perform the merge....
    Lorys
    click link to PM me
  • In Batch Convert (Like in "Save file As...")  you can set the "Options" for V8-DGN saving.
    Edit>V8-Options|References- There you are able to set how attached References are handled. All in one go.
    (try the option "Merge as cell": then your references will at least be maintained together as a cell afterthe merge)
    BTW. If you want to send out files and make sure all references are collected: Use the option "Convert References" (even for DGN) and save into a separate folder. All files will then be flat together with the references in that separate folder.
