how to change text into same direction in one process..??. i have so many text.. and if i have to change one by one... it takes time.... thanks
Which version of MicroStation are you using? That will make a difference
MaryB
The following workflow from the old AskInga pages may be helpful in changing the rotation for a large amount of selected text at the same time.
https://communities.bentley.com/products/microstation/w/askinga/800/change-various-text-rotations-all-at-once
In addition, there is another option:
https://communities.bentley.com/products/microstation/w/askinga/3313/active-angle-assistant-macro-updated
Select elements and change angle in Element properties window. Unfortunately there is no command to for example rotate all cells/text to 0 degree so it is horizontal and either need macro or use element properties.
communities.bentley.com/.../rotate-text-placed-at-arbitrary-angle-back-to-0-or-90-degree
Oto said:Unfortunately there is no command to for example rotate all cells/text to 0
Doesn't the Active Angle Assistant mentioned by Judy Wong provide that function?
