change text into same direction
how to change text into same direction in one process..??. i have so many text.. and if i have to change one by one... it takes time.... thanks
  • But hey you can vote and it maybe will be included in U30 in year 2025
    Unfortunately or fortunately for me, I don't plan to switch from v8i to CONNECT Slight smileWink
  • It was easier in v8i
    Well, it turns out that this thread is about MicroStation V8i.
    It's possible that some answers here are irrelevant, since the responders — in the absence of information to the contrary — assume that you  are using the current version of MicroStation.
    Regards, Jon Summers
    LA Solutions
  • You are fortunate as is it is easy in MSBASIC and v8i is still supported. Copy it to txt, rename to bas and you are good to go.
    This script rotates selected element or elements to zero degrees.
    'Rotate to zero
    'Selection set or element
    Function alfa#(sine#,cosine#)
        If cosine = 0.0 Then
            If sine > 0.0 Then
                angle# = 90.0
            Else
                angle = 270.0
            End If
        Else
            angle = Atn(sine / cosine) * 180.0# / PI
            If cosine < 0.0 Then
                angle = angle + 180.0
            ElseIf sine < 0.0 Then
                angle = angle + 360.0
            End If
        End If
        alfa = angle
    End Function
    Sub main
        Dim point As MbePoint,origin As MbePoint
        Dim elemSet as New MbeElementSet
         Dim setMember as MbeSetMember
        Dim element as new MbeElement
        Dim rotation(2, 2) as Double
         MbeSendCommand "ACTIVE ANGLE 0°"
    If elemSet.fromSelectionSet (1) <> MBE_Success Then
            If elemSet.fromFence() <> MBE_Success Then
                MbeWriteStatus "No fence or selection set"
            Else
                MbeWriteStatus "Processing Fence"
            End If
        Else
            MbeWriteStatus "Processing Selection Set"
        End If
        MbeSendCommand "MARK"
        status = elemSet.getFirst(setMember)
        Do While status = MBE_Success
            filePos& = element.fromFile(setMember.filePos, setMember.fileNum)
            If element.isGraphics <> 0 Then
          '      If element.type = MBE_Text Then
                    If element.getRotation(rotation) = MBE_Success Then
                        lenkis#=(360-alfa(rotation(1,0),rotation(0,0)))*PI/180
                        If element.getOrigin(origin) = MBE_Success Then
                            If element.rotate(lenkis,0,0,origin) = MBE_Success Then
                                stat=element.rewrite()
                            End If
                     '   End If
                    End If
                End If
            End If
        status = elemSet.getNext (setMember)
        Loop
        elemSet.clear
        MbeSendCommand "PLACE FENCE ICON "
        Do
            MbeStartLocate
            MbeWritePrompt "Choose element"
            MbeGetInput MBE_DataPointInput, MBE_ResetInput
            If MbeState.inputType = MBE_DataPointInput Then
                stat = MbeState.getInputDataPoint(point)
                MbeSendLastInput
                filePos&=element.fromLocate()
                If filePos>=0 Then
                            End If
                        End If
                    End If
                End If
            Else
                MbeSendReset
                MbeStartDefaultCommand
                End
            End If
        Loop
    End Sub
    Original author left so not sure if thread was about CONNECT or v8i version
    Oto, Thank you for your feedback
    Fortunately with some help of my friend programmer, I could achieve this need with the use of VBA code.
    You just need to change/enter angle value and level name(s) in the code and vualia.
    Angle = Radians(ENTER.YOUR.ANGLE.VALUE)
    oScanCriteria.IncludeLevel ActiveDesignFile.Levels("ENTER.YOUR.LEVEL.NAME1")
    Sub RotateElementAboutZ(ele As Element, pntFixed As Point3d, dblRadians As Double)
        Dim RotationMatrix As Matrix3d
        Dim Eltrans As Transform3d
        Dim Axis As Point3d
        Axis.X = 0
        Axis.Y = 0
        Axis.Z = 1
        RotationMatrix = Matrix3dFromVectorAndRotationAngle(Axis, dblRadians)
        Eltrans = Transform3dFromMatrix3dAndFixedPoint3d(RotationMatrix, pntFixed)
        ele.Transform Eltrans
    End Sub
    Sub RotateText()
        Dim xRot As Double, yRot As Double, zRot As Double, uniformScale As Double
        Dim Angle As Double
        Dim oScanCriteria As ElementScanCriteria
        Set oScanCriteria = New ElementScanCriteria
        oScanCriteria.ExcludeAllLevels
    	oScanCriteria.IncludeLevel ActiveDesignFile.Levels("ENTER.YOUR.LEVEL.NAME2")
        Dim oElEnum As ElementEnumerator
        Set oElEnum = ActiveModelReference.Scan(oScanCriteria)
        While oElEnum.MoveNext
            If oElEnum.Current.Type = msdElementTypeText Then
                With oElEnum.Current.AsTextElement
                    Matrix3dIsXRotationYRotationZRotationScale .Rotation, xRot, yRot, zRot, uniformScale
                    .Redraw msdDrawingModeErase
                    RotateElementAboutZ oElEnum.Current, .Origin, -zRot
                    RotateElementAboutZ oElEnum.Current, .Origin, Angle
                    .Rewrite
                    .Redraw
                End With
            End If
        Wend
    End Sub
