MicroStation Connect v10.11.0.36 - Key In Commands for Dimensioning
Hi everyone,
I am trying to created my own shortcuts in MicroStation Connect v10.11.0.36
Does anyone know the Key-In commands for the following?
  • Element Dimensioning
  • Linear Dimensioning
  • Angular Dimensioning
  • and Element Dimensioning (Circles and arcs)
Thank you very much.
Also, if possible, how can you find out a Key-In of a toolbox without the need of asking the Forum?
You can do the opposite (looking what a Key-In does) in MicroStation CONNECT Edition Help -> Key-in Index
Thank you,
Luis.
    1) DIMCREATE ELEMENT
    2) DIMCREATE LINEAR
    3) DIMCREATE ANGULAR
    4) DIMCREATE ELEMENT DIAMETER or DIMCREATE ELEMENT RADIUS
    Just go to the respective tool help page and at the bottom there's usually the key-in.
    Answer Verified By: Luis Marin Hinestrosa
  • Does anyone know the Key-In commands for the following?
    If you can't find a key-in in MicroStation help, then here's an alternative suggestion.
    Record a VBA macro while you use a tool.  The macro should record your key-in, plus any tool settings that you set or change while using the tool.  I'm not suggesting that you write VBA — simply use the recording to provide an insight into what happens when you use a tool.
    Regards, Jon Summers
    LA Solutions
  • accudraw activate
    accudraw bump
    accudraw bump toolsetting
    accudraw dialog
    accudraw dialog getacs
    accudraw dialog main
    accudraw dialog saveacs
    accudraw dialog settings
    accudraw dialog shortcuts
    accudraw dialog snapdivisor
    accudraw lock
    accudraw lock angle
    accudraw lock distance
    accudraw lock index
    accudraw lock smart
    accudraw lock x
    accudraw lock y
    accudraw lock z
    accudraw mode
    accudraw quit
    ACCUSNAP
    ACCUSNAP AUTOLOCATE
    ACCUSNAP AUTOLOCATE OFF
    ACCUSNAP AUTOLOCATE ON
    ACCUSNAP AUTOLOCATE TOGGLE
    ACCUSNAP OFF
    ACCUSNAP ON
    ACCUSNAP SUSPEND
    ACCUSNAP TOGGLE
    ACTIVE ANGLE
    ACTIVE ANGLE PT2
    ACTIVE ANGLE PT3
    ACTIVE AREA
    ACTIVE AREA HOLE
    ACTIVE AREA SOLID
    ACTIVE AREA TOGGLE
    ACTIVE AXIS
    ACTIVE AXORIGIN
    ACTIVE BACKGROUND
    active bspline
    active bspline closed
    active bspline open
    active bspline order
    active bspline periodic off
    active bspline periodic on
    active bspline periodic toggle
    active bspline pole
    active bspline polygon off
    active bspline polygon on
    active bspline polygon toggle
    active bspline rho
    active bspline tolerance
    active bspline uclosed
    active bspline uopen
    active bspline uorder
    active bspline upole
    active bspline urules
    active bspline vclosed
    active bspline vopen
    active bspline vorder
    active bspline vpole
    active bspline vrules
    ACTIVE CAPMODE
    ACTIVE CAPMODE OFF
    ACTIVE CAPMODE ON
    ACTIVE CAPMODE TOGGLE
    ACTIVE CELL
    ACTIVE CLASS
    ACTIVE CLASS CONSTRUCTION
    ACTIVE CLASS PRIMARY
    ACTIVE COLOR
    ACTIVE COLOR BLUE
    ACTIVE COLOR BYCELL
    ACTIVE COLOR BYLEVEL
    ACTIVE COLOR CSELECT (*)
    ACTIVE COLOR GREEN
    ACTIVE COLOR ORANGE
    ACTIVE COLOR OUTLINE (*)
    ACTIVE COLOR RED
    ACTIVE COLOR VIOLET
    ACTIVE COLOR WHITE
    ACTIVE COLOR YELLOW
    ACTIVE DATABASE
    ACTIVE DATYPE
    ACTIVE ENTITY
    ACTIVE FILL
    ACTIVE FILL OFF
    ACTIVE FILL ON
    ACTIVE FILL TOGGLE
    ACTIVE FILLCOLOR
    ACTIVE FILLCOLOR BLUE
    ACTIVE FILLCOLOR BYCELL
    ACTIVE FILLCOLOR BYLEVEL
    ACTIVE FILLCOLOR CSELECT (*)
    ACTIVE FILLCOLOR GREEN
    ACTIVE FILLCOLOR ORANGE
    ACTIVE FILLCOLOR OUTLINE (*)
    ACTIVE FILLCOLOR RED
    ACTIVE FILLCOLOR VIOLET
    ACTIVE FILLCOLOR WHITE
    ACTIVE FILLCOLOR YELLOW
    ACTIVE FONT
    ACTIVE GRIDANGLE
    ACTIVE GRIDMODE
    ACTIVE GRIDMODE ISOMETRIC
    ACTIVE GRIDMODE OFFSET
    ACTIVE GRIDMODE ORTHOGONAL
    ACTIVE GRIDMODE TOGGLE (*)
    ACTIVE GRIDORIENTATION
    ACTIVE GRIDORIENTATION ACS
    ACTIVE GRIDORIENTATION FRONT
    ACTIVE GRIDORIENTATION RIGHT
    ACTIVE GRIDORIENTATION TOP
    ACTIVE GRIDORIENTATION VIEW
    ACTIVE GRIDRATIO
    ACTIVE GRIDREF
    ACTIVE GRIDUNIT
    ACTIVE KEYPNT
    ACTIVE LEVEL
    ACTIVE LINE
    ACTIVE LINE LENGTH
    ACTIVE LINE SPACE
    ACTIVE LINESTYLESCALE
    ACTIVE LINEWIDTH (*)
    ACTIVE LINKAGE
    ACTIVE NODE
    ACTIVE ORIGIN
    ACTIVE PATTERN
    ACTIVE PATTERN ANGLE
    ACTIVE PATTERN CELL
    ACTIVE PATTERN DELTA
    ACTIVE PATTERN MATCH
    ACTIVE PATTERN SCALE
    ACTIVE PATTERN TOLERANCE
    ACTIVE POINT
    ACTIVE RCELL
    ACTIVE REPORT
    ACTIVE REVIEW
    ACTIVE SCALE
    ACTIVE SCALE DISTANCE
    ACTIVE STREAM
    ACTIVE STREAM ANGLE
    ACTIVE STREAM AREA
    ACTIVE STREAM DELTA
    ACTIVE STREAM TOLERANCE
    ACTIVE STYLE
    ACTIVE STYLE BYCELL
    ACTIVE STYLE BYLEVEL
    ACTIVE STYLE CSELECT (*)
    ACTIVE SYMBOLOGY
    ACTIVE SYMBOLOGY BYCELL
    ACTIVE SYMBOLOGY BYLEVEL
    ACTIVE TAB
    ACTIVE TAG
    ACTIVE TERMINATOR
    ACTIVE TEXT
    ACTIVE TNJ
    ACTIVE TNJ CB
    ACTIVE TNJ CC
    ACTIVE TNJ CT
    ACTIVE TNJ LB
    ACTIVE TNJ LC
    ACTIVE TNJ LMB
    ACTIVE TNJ LMC
    ACTIVE TNJ LMT
    ACTIVE TNJ LT
    ACTIVE TNJ RB
    ACTIVE TNJ RC
    ACTIVE TNJ RMB
    ACTIVE TNJ RMC
    ACTIVE TNJ RMT
    ACTIVE TNJ RT
    ACTIVE TSCALE
    ACTIVE TXCHARSPACE
    ACTIVE TXHEIGHT
    ACTIVE TXHEIGHT PT2
    ACTIVE TXJ
    ACTIVE TXJ CB
    ACTIVE TXJ CC
    ACTIVE TXJ CT
    ACTIVE TXJ LB
    ACTIVE TXJ LC
    ACTIVE TXJ LT
    ACTIVE TXJ RB
    ACTIVE TXJ RC
    ACTIVE TXJ RT
    ACTIVE TXSIZE
    ACTIVE TXSLANT
    ACTIVE TXUNDERLINE
    ACTIVE TXUNDERLINE OFF
    ACTIVE TXUNDERLINE ON
    ACTIVE TXUNDERLINE TOGGLE
    ACTIVE TXVERTICAL
    ACTIVE TXVERTICAL OFF
    ACTIVE TXVERTICAL ON
    ACTIVE TXVERTICAL TOGGLE
    ACTIVE TXWIDTH
    ACTIVE TXWIDTH PT2
    ACTIVE UNITRATIO
    ACTIVE UNITROUND
    ACTIVE WEIGHT
    ACTIVE WEIGHT BYCELL
    ACTIVE WEIGHT BYLEVEL
    ACTIVE WEIGHT CSELECT (*)
    ACTIVE XSCALE
    ACTIVE YSCALE
    ACTIVE ZDEPTH
    ACTIVE ZDEPTH ABSOLUTE
    ACTIVE ZDEPTH RELATIVE
    ACTIVE ZSCALE
    ALIGN
    align snap
    align snap element
    align snap point
    alignedge
    analyze
    analyze curvature
    analyze curvature point
    analyze curvature relative
    analyze element
    analyze old
    analyze old dialog
    analyze tree
    animator
    animator actor
    animator actor attach
    animator actor create
    animator actor detach
    animator actor drop
    animator actor manipulate
    animator actor modify
    animator actor origin
    animator actor path
    animator actor path copy
    animator actor path define
    animator animate
    animator animate general
    animator animate globallighting
    animator animate lighting
    animator animate material
    animator antialias
    animator antialias boxfilter off
    animator antialias boxfilter on
    animator antialias fieldfilterheight
    animator antialias filterheight
    animator antialias filterwidth
    animator camera
    animator camera create
    animator camera modify
    animator camera script
    animator camera view
    animator exit
    animator freeze
    animator keyframe
    animator keyframe create
    animator keyframe delete
    animator keyframe freeze
    animator keyframe namedcreate
    animator motionblur
    animator parameter
    animator parameter create
    animator parameter delete
    animator parameter edit
    animator preview
    animator preview addconetodgn
    animator preview end
    animator preview frame
    animator preview freeze
    animator preview next
    animator preview play
    animator preview previous
    animator preview rewind
    animator preview start
    animator quickvision
    animator quickvision save
    animator script
    animator script actor
    animator script adjust
    animator script clear
    animator script continue
    animator script edit
    animator script include
    animator script keyframe
    animator script open
    animator script preview
    animator script record
    animator script remove
    animator script rewind
    animator script save
    animator script saveas
    animator script scale
    animator script selected
    animator script view
    animator settings
    animator settings light
    animator settings material
    animator settings render
    animator target
    animator target create
    animator target script
    animator view
    animator view add
    APPLETVIEWER
    apply viewbox
    ARRAY
    ARRAY ICON
    ARRAY POLAR
    ARRAY RECTANGULAR
    assign equation
    assign variable
    ATTACH
    ATTACH ACS
    ATTACH AE
    ATTACH AE ICON
    attach arc
    attach circle
    ATTACH COLORTABLE
    ATTACH COLORTABLE BOTH (*)
    ATTACH COLORTABLE CREATE
    ATTACH COLORTABLE LEFT (*)
    ATTACH COLORTABLE RIGHT (*)
    ATTACH COLORTABLE WRITE
    attach curve
    attach curve catmullrom
    attach curve leastsquares
    attach curve points
    attach curve poles
    ATTACH DA
    attach dd
    ATTACH LIBRARY
    attach location
    attach lstring
    ATTACH MENU
    attach pen
    ATTACH REFERENCE
    attach tags
    attach transform
    attach webtag
    BACKUP
    BEEP
    blend bspline
    blend bspline curve
    blend bspline rails
    blend bspline surface
    blend curve
    blend rails
    blend surface
    boolean surface difference
    boolean surface intersection
    boolean surface union
    browser connect
    browser disconnect
    browser refagent
    capture
    capture automatic
    capture automatic off
    capture automatic on
    capture dialog
    capture focus
    capture palette
    capture rectangle
    capture screen
    capture view
    capture view contents
    capture view window
    CHAMFER
    chamfer surface
    CHANGE
    CHANGE AREA
    change brep display
    change bspline boundary
    change bspline close
    change bspline curve
    change bspline direction
    change bspline normal
    change bspline open
    change bspline order
    change bspline pole
    change bspline polygon
    change bspline rules
    change bspline uorder
    change bspline urules
    change bspline vorder
    change bspline vrules
    CHANGE CLASS
    CHANGE COLOR
    CHANGE COLOR ELEMENT
    CHANGE COLOR FILL
    CHANGE COLOR OUTLINE
    change curve
    CHANGE DIMENSION
    CHANGE DIMENSION EXTENSION
    CHANGE DIMENSION EXTENSION OFF
    CHANGE DIMENSION EXTENSION ON
    CHANGE DIMENSION EXTENSION TOGGLE
    CHANGE DIMENSION SYMBOLOGY
    CHANGE DIMENSION SYMBOLOGY ALTERNATE
    CHANGE DIMENSION SYMBOLOGY STANDARD
    CHANGE DIMENSION VIEW
    CHANGE DIMENSION WITNESS
    CHANGE DIMENSION WITNESS OFF
    CHANGE DIMENSION WITNESS ON
    CHANGE DIMENSION WITNESS TOGGLE
    change direction
    CHANGE FILL
    CHANGE ICON
    CHANGE LEVEL
    change linestyle scale
    CHANGE LOCK
    CHANGE MLINE
    change normal
    CHANGE STYLE
    CHANGE SYMBOLOGY
    change tags
    CHANGE UNLOCK
    change view displaymode
    change view perspective
    CHANGE WEIGHT
    changeby state
    CHOOSE
    CHOOSE ALL
    CHOOSE ELEMENT
    CHOOSE LAST
    CHOOSE NONE
    CHOOSE PREVIOUS
    clipboard background
    clipboard background off
    clipboard background on
    clipboard background toggle
    clipboard copy
    clipboard cut
    clipboard hide
    clipboard paste
    clipboard pastespecial
    clipboard show
    clipboard viewcopy
    CLOSE
    CLOSE DESIGN
    CLOSE ELEMENT
    COLORTABLE
    COLORTABLE DEFAULT
    COLORTABLE DUMP (*)
    COLORTABLE FILE (*)
    COMPRESS
    COMPRESS DESIGN
    COMPRESS DESIGN CONFIRM (*)
    COMPRESS LIBRARY
    constrain angle
    constrain assign
    constrain concentric
    constrain constant
    constrain dimension
    constrain element
    constrain equation
    constrain intersection
    constrain location
    constrain match
    constrain modify break
    constrain modify chamfer
    constrain modify fillet
    constrain modify model
    constrain modify tool
    constrain modify trim
    constrain parallel
    constrain perpendicular
    constrain pointon
    constrain set constraint
    constrain set post
    constrain set weak
    constrain smart
    constrain tangent
    constrain tool
    constrain variable
    CONSTRUCT
    construct arcs
    construct arcs interpolation
    CONSTRUCT BISECTOR
    CONSTRUCT BISECTOR ANGLE
    CONSTRUCT BISECTOR LINE
    construct bspline convert
    construct bspline convert copy
    construct bspline convert original
    construct curve offset
    construct curve reduce
    construct curve reparam
    construct curve tangents
    construct cut
    construct difference
    construct extrude along
    construct intersection
    CONSTRUCT LINE
    CONSTRUCT LINE AA
    CONSTRUCT LINE AA 1
    CONSTRUCT LINE AA 2
    CONSTRUCT LINE AA 2 DEFAULT (*)
    CONSTRUCT LINE AA 3
    CONSTRUCT LINE AA 4
    CONSTRUCT LINE AA 4 DEFAULT (*)
    CONSTRUCT LINE AA ICON
    CONSTRUCT LINE MINIMUM
    construct offset curve
    construct offset surface
    CONSTRUCT PERPENDICULAR
    CONSTRUCT PERPENDICULAR FROM
    CONSTRUCT PERPENDICULAR TO
    CONSTRUCT POINT
    CONSTRUCT POINT ALONG
    CONSTRUCT POINT ALONG DEFAULT (*)
    CONSTRUCT POINT BETWEEN
    CONSTRUCT POINT BETWEEN DEFAULT (*)
    CONSTRUCT POINT DISTANCE
    CONSTRUCT POINT DISTANCE DEFAULT (*)
    CONSTRUCT POINT INTERSECTION
    CONSTRUCT POINT PROJECT
    construct shell
    construct skin solid
    construct stitch
    construct surface crosssection
    construct surface edge
    construct surface helical
    construct surface network
    construct surface offset
    construct surface projection
    construct surface reduce
    construct surface reparam
    construct surface revolution
    construct surface sweep
    construct surface trace
    construct surface tube
    CONSTRUCT TANGENT
    CONSTRUCT TANGENT ARC
    CONSTRUCT TANGENT ARC 1
    CONSTRUCT TANGENT ARC 3
    CONSTRUCT TANGENT BETWEEN
    CONSTRUCT TANGENT CIRCLE
    CONSTRUCT TANGENT CIRCLE 1
    CONSTRUCT TANGENT CIRCLE 3
    CONSTRUCT TANGENT FROM
    CONSTRUCT TANGENT PERPENDICULAR
    CONSTRUCT TANGENT TO
    convert 3d
    convert brep
    convert bspline
    convert constant
    convert mesh
    convert no
    convert profile
    convert yes
    COPY
    COPY ED
    COPY ELEMENT
    copy extended
    COPY ICON
    COPY PARALLEL
    COPY PARALLEL DISTANCE
    COPY PARALLEL KEYIN
    COPY VIEW
    CREATE
    CREATE CELL
    CREATE CHAIN
    CREATE CHAIN AUTOMATIC
    CREATE CHAIN EOF (*)
    CREATE CHAIN ICON
    CREATE CHAIN MANUAL
    CREATE DRAWING
    CREATE ENTITY
    CREATE LIBRARY
    create region difference
    create region flood
    create region icon
    create region intersection
    create region union
    CREATE SHAPE
    CREATE SHAPE AUTOMATIC
    CREATE SHAPE AUTOMATIC DEFAULT (*)
    CREATE SHAPE EOF
    CREATE SHAPE ICON
    CREATE SHAPE MANUAL
    create symbol
    create viewbox
    crosshatch
    crosshatch difference
    crosshatch element
    crosshatch fence
    crosshatch flood
    crosshatch icon
    crosshatch intersection
    crosshatch points
    crosshatch union
    cut
    cut all
    cut single
    ddcell attach
    ddcell drop dim
    ddcell get parms all
    ddcell get parms design
    ddcell origin
    ddcell place
    ddcell rename
    ddcell set parms
    ddcell tool
    DEFINE
    DEFINE ACS
    DEFINE ACS ELEMENT
    DEFINE ACS ELEMENT CYLINDRICAL
    DEFINE ACS ELEMENT DEFAULT
    DEFINE ACS ELEMENT RECTANGULAR
    DEFINE ACS ELEMENT SPHERICAL
    DEFINE ACS POINTS
    DEFINE ACS POINTS CYLINDRICAL
    DEFINE ACS POINTS DEFAULT
    DEFINE ACS POINTS RECTANGULAR
    DEFINE ACS POINTS SPHERICAL
    DEFINE ACS VIEW
    DEFINE ACS VIEW CYLINDRICAL
    DEFINE ACS VIEW DEFAULT
    DEFINE ACS VIEW RECTANGULAR
    DEFINE ACS VIEW SPHERICAL
    DEFINE AE
    DEFINE CELL
    DEFINE CELL ATTRIBUTES
    DEFINE CELL ORIGIN
    DEFINE LIGHTS
    DEFINE MATERIALS
    DEFINE NORTH
    DEFINE SEARCH
    DELETE
    DELETE ACS
    DELETE CELL
    DELETE DIMVERTEX
    DELETE ELEMENT
    delete hatch
    DELETE PARTIAL
    delete pattern
    DELETE SCDEFS
    delete surface boundary
    delete symbol
    delete tags
    DELETE VERTEX
    DELETE VIEW
    delete webtag
    DEPTH
    DEPTH ACTIVE
    DEPTH ACTIVE INTERACTIVE (*)
    DEPTH ACTIVE PRIMITIVE (*)
    DEPTH DISPLAY
    DEPTH DISPLAY INTERACTIVE (*)
    DEPTH DISPLAY PRIMITIVE (*)
    deselect dynamic
    deselect dynamic elements
    DETACH
    DETACH DATABASE
    DETACH DATABASEICON
    DETACH LIBRARY
    dgnlib update all
    dgnlib update dimensionstyles
    dgnlib update levels
    dgnlib update textstyles
    DIALOG
    DIALOG ABOUTUSTN
    DIALOG ABOUTWORKMODE
    DIALOG ABOUTWORKSPACE
    DIALOG ACCUSNAP
    DIALOG ACTIVEANGLE
    DIALOG ACTIVESCALE
    DIALOG ADVISORY (*)
    dialog animator
    dialog attributes
    DIALOG BUTTONMAP
    DIALOG CAMERA
    DIALOG CELLMAINTENANCE
    DIALOG CMDBROWSE
    DIALOG COLOR
    DIALOG COMMAND (*)
    dialog coordsys
    DIALOG DATABASE
    DIALOG DIGITIZING
    dialog dimaltlabel
    dialog dimaltlabel open
    dialog dimaltlabel synchronize
    dialog dimattrib
    dialog dimattrib open
    dialog dimattrib synchronize
    dialog dimgeom
    dialog dimgeom open
    dialog dimgeom synchronize
    dialog dimplace
    dialog dimplace open
    dialog dimplace synchronize
    dialog dimsecunits
    dialog dimsecunits open
    dialog dimsecunits synchronize
    dialog dimsettings
    dialog dimsettings open
    dialog dimsettings synchronize
    dialog dimsymbol
    dialog dimsymbol open
    dialog dimsymbol synchronize
    dialog dimtemplate
    dialog dimtemplate open
    dialog dimtemplate synchronize
    dialog dimterminators
    dialog dimterminators open
    dialog dimterminators synchronize
    dialog dimtext
    dialog dimtext open
    dialog dimtext synchronize
    dialog dimtolerance
    dialog dimtolerance open
    dialog dimtolerance synchronize
    DIALOG DISPLAY
    DIALOG FENCEFRAME
    DIALOG FOCUS
    DIALOG FOCUS COMMAND
    DIALOG FUNCKEYS
    dialog geomtol
    dialog geturl
    DIALOG GRID
    DIALOG IMAGE
    DIALOG LOCKS
    DIALOG LOCKTOGGLES
    DIALOG LSTYLEEDIT (*)
    DIALOG LSTYLESETUP (*)
    DIALOG MAINFRAME
    DIALOG MDL
    dialog namedviews
    DIALOG OPENFILE
    DIALOG PALETTE
    dialog palette 3dfillet
    dialog palette 3dmodify
    dialog palette 3dprimitive
    dialog palette 3dtools
    dialog palette 3dview
    DIALOG PALETTE 40LINE
    DIALOG PALETTE 50ARC
    DIALOG PALETTE 50CELL
    DIALOG PALETTE 50CHAIN
    DIALOG PALETTE 50CHANGE
    DIALOG PALETTE 50CIRCLE
    DIALOG PALETTE 50CURVE
    DIALOG PALETTE 50DROP
    DIALOG PALETTE 50FENCE
    DIALOG PALETTE 50FILLET
    DIALOG PALETTE 50LINE
    DIALOG PALETTE 50MANIPULATE
    DIALOG PALETTE 50MODIFY
    DIALOG PALETTE 50POINT
    DIALOG PALETTE 50POLYGON
    DIALOG PALETTE 50TEXT
    DIALOG PALETTE 50VIEWCONTROL
    DIALOG PALETTE ACS
    dialog palette angulardimen
    DIALOG PALETTE ARC
    dialog palette attach
    dialog palette booleans
    DIALOG PALETTE CELL
    DIALOG PALETTE CHAIN
    DIALOG PALETTE CHANGE
    DIALOG PALETTE CIRCLE
    dialog palette constraint
    DIALOG PALETTE COPYELEMENT
    dialog palette cutter
    DIALOG PALETTE DATABASE
    dialog palette dddesign
    dialog palette dimension
    DIALOG PALETTE DROP
    DIALOG PALETTE ENTERDATA
    DIALOG PALETTE FENCECHANGE
    DIALOG PALETTE FENCECOPY
    DIALOG PALETTE FENCEDELETE
    DIALOG PALETTE FENCEMIRROR
    DIALOG PALETTE FILLET
    dialog palette lineardimen
    DIALOG PALETTE LINESTRING
    DIALOG PALETTE MIRRORELEMENT
    dialog palette miscdimen
    dialog palette model
    DIALOG PALETTE MODIFY
    DIALOG PALETTE PLACEFENCE
    DIALOG PALETTE POINT
    DIALOG PALETTE POLYGON
    dialog palette radialdimen
    DIALOG PALETTE REFERENCEFILE
    dialog palette sketch
    dialog palette spline
    dialog palette tags
    DIALOG PALETTE TEXT
    DIALOG PALETTE THREED
    dialog palette transfrm
    DIALOG PALETTE VIEWCONTROL
    DIALOG PALETTE WORKSPACE1(*)
    DIALOG PALETTE WORKSPACE2 (*)
    DIALOG PALETTE WORKSPACE3 (*)
    DIALOG PALETTE WORKSPACE4 (*)
    DIALOG PALETTE WORKSPACE5 (*)
    DIALOG PALETTE WORKSPACE6 (*)
    DIALOG PALETTE WORKSPACE7 (*)
    DIALOG PALETTE WORKSPACE8 (*)
    DIALOG PALETTE WORKSPACE9 (*)
    dialog particletrace
    DIALOG PLOT
    dialog popset
    dialog popset properties
    DIALOG PREVIEW
    DIALOG PROPERTIES
    dialog radiosity
    dialog raster
    dialog raster edit
    dialog raster views
    dialog raytrace
    DIALOG READOUT
    dialog reference
    DIALOG RENDER
    dialog rotateacs
    DIALOG SAVEAS
    DIALOG SAVEIMAGE
    dialog settings splines
    dialog smartsolid
    DIALOG SNAPBUTTONS
    DIALOG SNAPS (*)
    DIALOG SNAPVERTICAL (*)
    DIALOG STANDARDALERT (*)
    dialog tags report
    dialog tags sets
    dialog tags template
    DIALOG TEXTEDIT
    DIALOG TOOLBOX
    DIALOG TOOLBOX 2DVIEWING
    DIALOG TOOLBOX 3DCONSTRUCT
    DIALOG TOOLBOX 3DDRAWING
    DIALOG TOOLBOX 3DFILLET
    DIALOG TOOLBOX 3DFREEFORM
    DIALOG TOOLBOX 3DMODIFY
    DIALOG TOOLBOX 3DMODSURF
    DIALOG TOOLBOX 3DQUERY
    DIALOG TOOLBOX 3DTOOLS
    DIALOG TOOLBOX 3DVIEWING
    DIALOG TOOLBOX ACS
    dialog toolbox animation
    dialog toolbox animation actors
    dialog toolbox animation cameras
    dialog toolbox animation preview
    dialog toolbox animation settings
    DIALOG TOOLBOX ANNOTATE
    DIALOG TOOLBOX ANNOTATION
    DIALOG TOOLBOX ARC
    DIALOG TOOLBOX ATTRIBUTES
    DIALOG TOOLBOX BSPLINE
    DIALOG TOOLBOX CELLS
    DIALOG TOOLBOX CHANGE
    DIALOG TOOLBOX CURVE
    DIALOG TOOLBOX CURVECREATE
    DIALOG TOOLBOX CURVEMODIFY
    DIALOG TOOLBOX DATABASE
    DIALOG TOOLBOX DDDATTACH
    DIALOG TOOLBOX DDDCONSTRAINT
    DIALOG TOOLBOX DDDDRAW
    DIALOG TOOLBOX DDDMODEL
    DIALOG TOOLBOX DDDMODIFY
    DIALOG TOOLBOX DDDPARM
    DIALOG TOOLBOX DDDTOOLS
    DIALOG TOOLBOX DIMANGULAR
    DIALOG TOOLBOX DIMENSION
    DIALOG TOOLBOX DIMLINEAR
    DIALOG TOOLBOX DIMMISC
    DIALOG TOOLBOX DIMRADIAL
    DIALOG TOOLBOX DIMTOOL
    DIALOG TOOLBOX DRFTOOLS
    DIALOG TOOLBOX DROP
    DIALOG TOOLBOX ELLIPSES
    DIALOG TOOLBOX EXTRACT
    DIALOG TOOLBOX FENCE
    DIALOG TOOLBOX FILLET
    DIALOG TOOLBOX GROUPS
    DIALOG TOOLBOX HATCH
    DIALOG TOOLBOX HISTORY
    DIALOG TOOLBOX ISOMETRIC
    DIALOG TOOLBOX JOINTS
    DIALOG TOOLBOX LINE
    DIALOG TOOLBOX LINEAR (*)
    DIALOG TOOLBOX MAIN
    DIALOG TOOLBOX MANIPULATE
    DIALOG TOOLBOX MATCH
    DIALOG TOOLBOX MEASURE
    DIALOG TOOLBOX MODIFY
    DIALOG TOOLBOX PATTERNS
    DIALOG TOOLBOX POINTS
    DIALOG TOOLBOX POLYGONS
    DIALOG TOOLBOX PRIMARY
    DIALOG TOOLBOX REDLINE
    DIALOG TOOLBOX REFERENCE
    DIALOG TOOLBOX SELECTION
    DIALOG TOOLBOX SOLID
    DIALOG TOOLBOX STANDARD
    DIALOG TOOLBOX SURFACE
    DIALOG TOOLBOX TAGS
    DIALOG TOOLBOX TEXT
    DIALOG TOOLBOX VIEWCONTROL
    DIALOG TOOLBOX VIEWGROUPS
    DIALOG TOOLBOX VISUALIZATION
    DIALOG TOOLBOX XYZTXT
    DIALOG TOOLSETTINGS
    dialog viewctrl
    dialog viewgroups
    DIALOG VIEWRENDERSET
    DIALOG VIEWROTATION
    DIALOG VIEWSETTINGS
    dialog webtools
    DIGITIZER
    DIGITIZER DOWNLOAD (*)
    DIGITIZER PARTITION
    DIGITIZER SETUP
    DIMENSION
    dimension angle
    dimension angle chamfer
    dimension angle lines
    dimension angle location
    dimension angle size
    dimension angle x
    dimension angle y
    dimension arc distance
    dimension arc location
    dimension arc size
    DIMENSION ARCLENGTH
    DIMENSION ARCLENGTH OFF
    DIMENSION ARCLENGTH ON
    DIMENSION ARCLENGTH TOGGLE
    DIMENSION AXIS
    DIMENSION AXIS ARBITRARY
    DIMENSION AXIS DRAWING
    DIMENSION AXIS TRUE
    DIMENSION AXIS VIEW
    DIMENSION CENTER
    dimension center mark
    DIMENSION CENTER OFF
    DIMENSION CENTER ON
    DIMENSION CENTER SIZE
    dimension chamfer
    dimension chamfer all
    dimension chamfer angle
    dimension chamfer next
    dimension chamfer note
    dimension chamfer xtheta
    dimension chamfer xy
    DIMENSION COLOR
    DIMENSION COLOR BLUE
    DIMENSION COLOR BYCELL
    DIMENSION COLOR BYLEVEL
    DIMENSION COLOR CSELECT (*)
    DIMENSION COLOR GREEN
    DIMENSION COLOR ORANGE
    DIMENSION COLOR OUTLINE (*)
    DIMENSION COLOR RED
    DIMENSION COLOR VIOLET
    DIMENSION COLOR WHITE
    DIMENSION COLOR YELLOW
    dimension diameter
    dimension diameter extended
    dimension diameter note
    dimension diameter parallel
    dimension diameter perpendicular
    dimension diameter point
    dimension element
    DIMENSION EXTENSION
    DIMENSION EXTENSION BOTTOM
    DIMENSION EXTENSION BOTTOM OFF
    DIMENSION EXTENSION BOTTOM ON
    DIMENSION EXTENSION BOTTOM TOGGLE
    DIMENSION EXTENSION LEFT
    DIMENSION EXTENSION LEFT OFF
    DIMENSION EXTENSION LEFT ON
    DIMENSION EXTENSION LEFT TOGGLE
    DIMENSION EXTENSION RIGHT
    DIMENSION EXTENSION RIGHT OFF
    DIMENSION EXTENSION RIGHT ON
    DIMENSION EXTENSION RIGHT TOGGLE
    DIMENSION EXTENSION TOP
    DIMENSION EXTENSION TOP OFF
    DIMENSION EXTENSION TOP ON
    DIMENSION EXTENSION TOP TOGGLE
    DIMENSION FILE
    DIMENSION FILE ACTIVE
    DIMENSION FILE REFERENCE
    DIMENSION FONT
    DIMENSION FONT ACTIVE
    dimension half
    DIMENSION JUSTIFICATION
    DIMENSION JUSTIFICATION CENTER
    DIMENSION JUSTIFICATION LEFT
    DIMENSION JUSTIFICATION RIGHT
    DIMENSION LEVEL
    DIMENSION LEVEL ACTIVE
    dimension linear
    dimension location
    dimension location single
    dimension location stacked
    dimension modtolerance
    dimension next
    dimension ordinate
    DIMENSION PLACEMENT
    DIMENSION PLACEMENT AUTO
    DIMENSION PLACEMENT MANUAL
    DIMENSION PLACEMENT SEMIAUTO
    DIMENSION POST
    DIMENSION POST DIAMETER
    DIMENSION POST OFF
    DIMENSION POST RADIUS
    DIMENSION POST SQUARE
    DIMENSION PRE
    DIMENSION PRE DIAMETER
    DIMENSION PRE OFF
    DIMENSION PRE RADIUS
    DIMENSION PRE SQUARE
    dimension radial
    dimension radius
    dimension radius extended
    dimension radius note
    dimension radius point
    dimension reassociate
    DIMENSION SCALE
    DIMENSION SCALE RESET
    dimension size
    dimension size arrow
    dimension size perpendicular
    dimension size perpendicular element
    dimension size perpendicular line
    dimension size perpendicular points
    dimension size stroke
    DIMENSION STACKED
    DIMENSION STACKED OFF
    DIMENSION STACKED ON
    DIMENSION STACKED TOGGLE
    dimension symmetric
    DIMENSION TERMINATOR
    DIMENSION TERMINATOR FIRST
    DIMENSION TERMINATOR FIRST ARROW
    DIMENSION TERMINATOR FIRST OFF
    DIMENSION TERMINATOR FIRST ORIGIN
    DIMENSION TERMINATOR FIRST STROKE
    DIMENSION TERMINATOR LEFT
    DIMENSION TERMINATOR LEFT ARROW
    DIMENSION TERMINATOR LEFT OFF
    DIMENSION TERMINATOR LEFT ORIGIN
    DIMENSION TERMINATOR LEFT STROKE
    DIMENSION TERMINATOR RIGHT
    DIMENSION TERMINATOR RIGHT ARROW
    DIMENSION TERMINATOR RIGHT OFF
    DIMENSION TERMINATOR RIGHT ORIGIN
    DIMENSION TERMINATOR RIGHT STROKE
    DIMENSION TEXT
    DIMENSION TEXT BOX
    DIMENSION TEXT BOX OFF
    DIMENSION TEXT BOX ON
    DIMENSION TEXT BOX TOGGLE
    DIMENSION TEXT CAPSULE
    DIMENSION TEXT CAPSULE OFF
    DIMENSION TEXT CAPSULE ON
    DIMENSION TEXT CAPSULE TOGGLE
    DIMENSION TEXT COLOR
    DIMENSION TEXT COLOR BLUE
    DIMENSION TEXT COLOR BYCELL
    DIMENSION TEXT COLOR BYLEVEL
    DIMENSION TEXT COLOR CSELECT (*)
    DIMENSION TEXT COLOR GREEN
    DIMENSION TEXT COLOR ORANGE
    DIMENSION TEXT COLOR OUTLINE
    DIMENSION TEXT COLOR RED
    DIMENSION TEXT COLOR VIOLET
    DIMENSION TEXT COLOR WHITE
    DIMENSION TEXT COLOR YELLOW
    DIMENSION TEXT WEIGHT
    DIMENSION TEXT WEIGHT ACTIVE
    DIMENSION TOLERANCE
    DIMENSION TOLERANCE LOWER
    DIMENSION TOLERANCE SCALE
    DIMENSION TOLERANCE UPPER
    DIMENSION UNITS
    DIMENSION UNITS DEGREES
    DIMENSION UNITS LENGTH
    DIMENSION UPDATE
    DIMENSION VERTICAL
    DIMENSION VERTICAL MIXED
    DIMENSION VERTICAL OFF
    DIMENSION VERTICAL ON
    DIMENSION WEIGHT
    DIMENSION WEIGHT ACTIVE
    DIMENSION WITNESS
    DIMENSION WITNESS BOTTOM
    DIMENSION WITNESS BOTTOM OFF
    DIMENSION WITNESS BOTTOM ON
    DIMENSION WITNESS BOTTOM TOGGLE
    DIMENSION WITNESS LEFT
    DIMENSION WITNESS LEFT OFF
    DIMENSION WITNESS LEFT ON
    DIMENSION WITNESS LEFT TOGGLE
    DIMENSION WITNESS RIGHT
    DIMENSION WITNESS RIGHT OFF
    DIMENSION WITNESS RIGHT ON
    DIMENSION WITNESS RIGHT TOGGLE
    DIMENSION WITNESS TOP
    DIMENSION WITNESS TOP OFF
    DIMENSION WITNESS TOP ON
    DIMENSION WITNESS TOP TOGGLE
    dimstyle import
    DISPLAY
    DISPLAY ERASE
    DISPLAY HILITE
    DISPLAY SET
    DMSG
    DMSG ACTION
    DMSG ACTION ADDMODE
    DMSG ACTION ADDMODE OFF
    DMSG ACTION ADDMODE ON
    DMSG ACTION ADDMODE TOGGLE
    DMSG ACTION CANCEL
    DMSG ACTION DOCMENUCLOSE
    DMSG ACTION EXTENDMODE
    DMSG ACTION EXTENDMODE OFF
    DMSG ACTION EXTENDMODE ON
    DMSG ACTION EXTENDMODE TOGGLE
    DMSG ACTION FUNCKEY
    DMSG ACTION KEYIN
    DMSG ACTION MENUBAR
    DMSG ACTION MENUBAR OFF
    DMSG ACTION MENUBAR ON
    DMSG ACTION MENUBAR TOGGLE
    DMSG ACTION OKAY
    DMSG ACTION POPUP
    DMSG ACTION POPUP OFF
    DMSG ACTION POPUP ON
    DMSG ACTION POPUP TOGGLE
    DMSG ACTION QNEXTWINDOW
    DMSG ACTION QPOPUP
    DMSG ACTION QPREVWINDOW
    DMSG ACTION SELECT
    DMSG ACTION SHOWACCELERATORS
    DMSG ACTION SHOWMNEMONICS
    DMSG ACTION SYSMENUCHNGSCRN
    DMSG ACTION SYSMENUCLOSE
    DMSG ACTION SYSMENULOWER
    DMSG ACTION SYSMENUMAXIMIZE
    DMSG ACTION SYSMENUMINIMIZE
    DMSG ACTION SYSMENUMOVE
    DMSG ACTION SYSMENUPULL
    DMSG ACTION SYSMENURESTORE
    DMSG ACTION SYSMENUSINK
    DMSG ACTION SYSMENUSIZE
    DMSG APPENDMSGFILE
    DMSG AUXMSGDEBUG
    DMSG AUXMSGDEBUG OFF
    DMSG AUXMSGDEBUG ON
    DMSG AUXMSGDEBUG TOGGLE
    DMSG CANCEL
    DMSG CLEARDEBUG
    DMSG CLIPBOARD
    DMSG CLIPBOARD CLEAR
    DMSG CLIPBOARD COPY
    DMSG CLIPBOARD CUT
    DMSG CLIPBOARD DELETE
    DMSG CLIPBOARD INSERTTEXT
    DMSG CLIPBOARD PASTE
    DMSG CLIPBOARD REDO
    DMSG CLIPBOARD UNDO
    DMSG CLOSEALLDIALOGS
    DMSG CLOSEALLFRAMES
    DMSG CLOSEDIALOG
    DMSG CLOSEMSGFILE
    DMSG CLOSEPALETTE
    DMSG CLOSESUBPALETTES
    DMSG CLOSETOOLBOXES
    DMSG CLOSETOOLBOXES ALL
    DMSG CLOSETOOLBOXES DOCKED
    DMSG CLOSETOOLBOXES UNDOCKED
    DMSG CURSOR
    DMSG CURSOR BLINK
    DMSG CURSOR BLINK OFF
    DMSG CURSOR BLINK ON
    DMSG CURSOR BLINK TOGGLE
    DMSG CURSOR DATABEGIN
    DMSG CURSOR DATAEND
    DMSG CURSOR DELETEDATABEGIN
    DMSG CURSOR DELETEDATAEND
    DMSG CURSOR DELETELEFT
    DMSG CURSOR DELETELEFTWORD
    DMSG CURSOR DELETERIGHT
    DMSG CURSOR DELETERIGHTWORD
    DMSG CURSOR DESELECTALL
    DMSG CURSOR DOWN
    DMSG CURSOR FOCUSDOWN
    DMSG CURSOR FOCUSUP
    DMSG CURSOR GLOBALDIRECTION
    DMSG CURSOR LEFT
    DMSG CURSOR LINEBEGIN
    DMSG CURSOR LINEEND
    DMSG CURSOR LOCALDIRECTION
    DMSG CURSOR NEXTDOCUMENT
    DMSG CURSOR NEXTFIELD
    DMSG CURSOR NEXTPANE
    DMSG CURSOR NEXTWINDOW
    DMSG CURSOR PAGEDOWN
    DMSG CURSOR PAGEUP
    DMSG CURSOR PREVIOUSDOCUMENT
    DMSG CURSOR PREVIOUSFIELD
    DMSG CURSOR PREVIOUSPANE
    DMSG CURSOR PREVIOUSPRIORITYWINDOW
    DMSG CURSOR PREVIOUSWINDOW
    DMSG CURSOR RIGHT
    DMSG CURSOR SELECTALL
    DMSG CURSOR TOGGLEINSERTMODE
    DMSG CURSOR UP
    DMSG CURSOR WORDLEFT
    DMSG CURSOR WORDRIGHT
    DMSG DIALOGDEBUG
    DMSG DIALOGDEBUG OFF
    DMSG DIALOGDEBUG ON
    DMSG DIALOGDEBUG TOGGLE
    DMSG DUMP
    DMSG DUMP ABOUTUSTN
    DMSG DUMP ABOUTWORKMODE
    DMSG DUMP ABOUTWORKSPACE
    DMSG DUMP ACCUSNAP
    DMSG DUMP ACTIVEANGLE
    DMSG DUMP ACTIVESCALE
    DMSG DUMP ADVISORY
    DMSG DUMP ATTRIBUTES
    DMSG DUMP BUTTONMAP
    DMSG DUMP CAMERA
    DMSG DUMP CELLMAINTENANCE
    DMSG DUMP CMDBROWSE
    DMSG DUMP COLOR
    DMSG DUMP COMMAND
    DMSG DUMP DATABASE
    DMSG DUMP DIGITIZING
    DMSG DUMP DISPLAY
    DMSG DUMP FENCEFRAME
    DMSG DUMP FOCUS
    DMSG DUMP FOCUS COMMAND
    DMSG DUMP FUNCKEYS
    DMSG DUMP GRID
    DMSG DUMP IMAGE
    DMSG DUMP LOCKS
    DMSG DUMP LOCKTOGGLES
    DMSG DUMP LSTYLEEDIT
    DMSG DUMP LSTYLESETUP
    DMSG DUMP MAINFRAME
    DMSG DUMP MDL
    DMSG DUMP OPENFILE
    DMSG DUMP PALETTE
    DMSG DUMP PALETTE 40LINE
    DMSG DUMP PALETTE 50ARC
    DMSG DUMP PALETTE 50CELL
    DMSG DUMP PALETTE 50CHAIN
    DMSG DUMP PALETTE 50CHANGE
    DMSG DUMP PALETTE 50CIRCLE
    DMSG DUMP PALETTE 50CURVE
    DMSG DUMP PALETTE 50DROP
    DMSG DUMP PALETTE 50FENCE
    DMSG DUMP PALETTE 50FILLET
    DMSG DUMP PALETTE 50LINE
    DMSG DUMP PALETTE 50MANIPULATE
    DMSG DUMP PALETTE 50MODIFY
    DMSG DUMP PALETTE 50POINT
    DMSG DUMP PALETTE 50POLYGON
    DMSG DUMP PALETTE 50TEXT
    DMSG DUMP PALETTE 50VIEWCONTROL
    DMSG DUMP PALETTE ACS
    DMSG DUMP PALETTE ARC
    DMSG DUMP PALETTE CELL
    DMSG DUMP PALETTE CHAIN
    DMSG DUMP PALETTE CHANGE
    DMSG DUMP PALETTE CIRCLE
    DMSG DUMP PALETTE COPYELEMENT
    DMSG DUMP PALETTE DATABASE
    DMSG DUMP PALETTE DROP
    DMSG DUMP PALETTE ENTERDATA
    DMSG DUMP PALETTE FENCECHANGE
    DMSG DUMP PALETTE FENCECOPY
    DMSG DUMP PALETTE FENCEDELETE
    DMSG DUMP PALETTE FENCEMIRROR
    DMSG DUMP PALETTE FILLET
    DMSG DUMP PALETTE LINESTRING
    DMSG DUMP PALETTE MIRRORELEMENT
    DMSG DUMP PALETTE MODIFY
    DMSG DUMP PALETTE PLACEFENCE
    DMSG DUMP PALETTE POINT
    DMSG DUMP PALETTE POLYGON
    DMSG DUMP PALETTE REFERENCEFILE
    DMSG DUMP PALETTE TEXT
    DMSG DUMP PALETTE THREED
    DMSG DUMP PALETTE VIEWCONTROL
    DMSG DUMP PALETTE WORKSPACE1
    DMSG DUMP PALETTE WORKSPACE2
    DMSG DUMP PALETTE WORKSPACE3
    DMSG DUMP PALETTE WORKSPACE4
    DMSG DUMP PALETTE WORKSPACE5
    DMSG DUMP PALETTE WORKSPACE6
    DMSG DUMP PALETTE WORKSPACE7
    DMSG DUMP PALETTE WORKSPACE8
    DMSG DUMP PALETTE WORKSPACE9
    DMSG DUMP PLOT
    DMSG DUMP PREVIEW
    DMSG DUMP PROPERTIES
    DMSG DUMP READOUT
    DMSG DUMP RENDER
    DMSG DUMP SAVEAS
    DMSG DUMP SAVEIMAGE
    DMSG DUMP SNAPBUTTONS
    DMSG DUMP SNAPS
    DMSG DUMP SNAPVERTICAL
    DMSG DUMP STANDARDALERT
    DMSG DUMP TEXTEDIT
    DMSG DUMP TOOLBOX
    DMSG DUMP TOOLBOX 2DVIEWING
    DMSG DUMP TOOLBOX 3DCONSTRUCT
    DMSG DUMP TOOLBOX 3DDRAWING
    DMSG DUMP TOOLBOX 3DFILLET
    DMSG DUMP TOOLBOX 3DFREEFORM
    DMSG DUMP TOOLBOX 3DMODIFY
    DMSG DUMP TOOLBOX 3DMODSURF
    DMSG DUMP TOOLBOX 3DQUERY
    DMSG DUMP TOOLBOX 3DTOOLS
    DMSG DUMP TOOLBOX 3DVIEWING
    DMSG DUMP TOOLBOX ACS
    DMSG DUMP TOOLBOX ANNOTATE
    DMSG DUMP TOOLBOX ANNOTATION
    DMSG DUMP TOOLBOX ARC
    DMSG DUMP TOOLBOX ATTRIBUTES
    DMSG DUMP TOOLBOX BSPLINE
    DMSG DUMP TOOLBOX CELLS
    DMSG DUMP TOOLBOX CHANGE
    DMSG DUMP TOOLBOX CURVE
    DMSG DUMP TOOLBOX CURVECREATE
    DMSG DUMP TOOLBOX CURVEMODIFY
    DMSG DUMP TOOLBOX DATABASE
    DMSG DUMP TOOLBOX DDDATTACH
    DMSG DUMP TOOLBOX DDDCONSTRAINT
    DMSG DUMP TOOLBOX DDDDRAW
    DMSG DUMP TOOLBOX DDDMODEL
    DMSG DUMP TOOLBOX DDDMODIFY
    DMSG DUMP TOOLBOX DDDPARM
    DMSG DUMP TOOLBOX DDDTOOLS
    DMSG DUMP TOOLBOX DIMANGULAR
    DMSG DUMP TOOLBOX DIMENSION
    DMSG DUMP TOOLBOX DIMLINEAR
    DMSG DUMP TOOLBOX DIMMISC
    DMSG DUMP TOOLBOX DIMRADIAL
    DMSG DUMP TOOLBOX DIMTOOL
    DMSG DUMP TOOLBOX DRFTOOLS
    DMSG DUMP TOOLBOX DROP
    DMSG DUMP TOOLBOX ELLIPSES
    DMSG DUMP TOOLBOX EXTRACT
    DMSG DUMP TOOLBOX FENCE
    DMSG DUMP TOOLBOX FILLET
    DMSG DUMP TOOLBOX GROUPS
    DMSG DUMP TOOLBOX HATCH
    DMSG DUMP TOOLBOX HISTORY
    DMSG DUMP TOOLBOX ISOMETRIC
    DMSG DUMP TOOLBOX JOINTS
    DMSG DUMP TOOLBOX LINE
    DMSG DUMP TOOLBOX LINEAR
    DMSG DUMP TOOLBOX MAIN
    DMSG DUMP TOOLBOX MANIPULATE
    DMSG DUMP TOOLBOX MATCH
    DMSG DUMP TOOLBOX MEASURE
    DMSG DUMP TOOLBOX MODIFY
    DMSG DUMP TOOLBOX PATTERNS
    DMSG DUMP TOOLBOX POINTS
    DMSG DUMP TOOLBOX POLYGONS
    DMSG DUMP TOOLBOX PRIMARY
    DMSG DUMP TOOLBOX REDLINE
    DMSG DUMP TOOLBOX REFERENCE
    DMSG DUMP TOOLBOX SELECTION
    DMSG DUMP TOOLBOX SOLID
    DMSG DUMP TOOLBOX STANDARD
    DMSG DUMP TOOLBOX SURFACE
    DMSG DUMP TOOLBOX TAGS
    DMSG DUMP TOOLBOX TEXT
    DMSG DUMP TOOLBOX VIEWCONTROL
    DMSG DUMP TOOLBOX VIEWGROUPS
    DMSG DUMP TOOLBOX VISUALIZATION
    DMSG DUMP TOOLBOX XYZTXT
    DMSG DUMP TOOLSETTINGS
    DMSG DUMP VIEWRENDERSET
    DMSG DUMP VIEWROTATION
    DMSG DUMP VIEWSETTINGS
    DMSG FOCUSDEBUG
    DMSG FOCUSDIALOG
    DMSG FOCUSDIALOG ABOUTUSTN
    DMSG FOCUSDIALOG ABOUTWORKMODE
    DMSG FOCUSDIALOG ABOUTWORKSPACE
    DMSG FOCUSDIALOG ACCUSNAP
    DMSG FOCUSDIALOG ACTIVEANGLE
    DMSG FOCUSDIALOG ACTIVESCALE
    DMSG FOCUSDIALOG ADVISORY
    DMSG FOCUSDIALOG ATTRIBUTES
    DMSG FOCUSDIALOG BUTTONMAP
    DMSG FOCUSDIALOG CAMERA
    DMSG FOCUSDIALOG CELLMAINTENANCE
    DMSG FOCUSDIALOG CMDBROWSE
    DMSG FOCUSDIALOG COLOR
    DMSG FOCUSDIALOG COMMAND
    DMSG FOCUSDIALOG DATABASE
    DMSG FOCUSDIALOG DIGITIZING
    DMSG FOCUSDIALOG DISPLAY
    DMSG FOCUSDIALOG FENCEFRAME
    DMSG FOCUSDIALOG FOCUS
    DMSG FOCUSDIALOG FOCUS COMMAND
    DMSG FOCUSDIALOG FUNCKEYS
    DMSG FOCUSDIALOG GRID
    DMSG FOCUSDIALOG IMAGE
    DMSG FOCUSDIALOG LOCKS
    DMSG FOCUSDIALOG LOCKTOGGLES
    DMSG FOCUSDIALOG LSTYLEEDIT
    DMSG FOCUSDIALOG LSTYLESETUP
    DMSG FOCUSDIALOG MAINFRAME
    DMSG FOCUSDIALOG MDL
    DMSG FOCUSDIALOG OPENFILE
    DMSG FOCUSDIALOG PALETTE
    DMSG FOCUSDIALOG PALETTE 40LINE
    DMSG FOCUSDIALOG PALETTE 50ARC
    DMSG FOCUSDIALOG PALETTE 50CELL
    DMSG FOCUSDIALOG PALETTE 50CHAIN
    DMSG FOCUSDIALOG PALETTE 50CHANGE
    DMSG FOCUSDIALOG PALETTE 50CIRCLE
    DMSG FOCUSDIALOG PALETTE 50CURVE
    DMSG FOCUSDIALOG PALETTE 50DROP
    DMSG FOCUSDIALOG PALETTE 50FENCE
    DMSG FOCUSDIALOG PALETTE 50FILLET
    DMSG FOCUSDIALOG PALETTE 50LINE
    DMSG FOCUSDIALOG PALETTE 50MANIPULATE
    DMSG FOCUSDIALOG PALETTE 50MODIFY
    DMSG FOCUSDIALOG PALETTE 50POINT
    DMSG FOCUSDIALOG PALETTE 50POLYGON
    DMSG FOCUSDIALOG PALETTE 50TEXT
    DMSG FOCUSDIALOG PALETTE 50VIEWCONTROL
    DMSG FOCUSDIALOG PALETTE ACS
    DMSG FOCUSDIALOG PALETTE ARC
    DMSG FOCUSDIALOG PALETTE CELL
    DMSG FOCUSDIALOG PALETTE CHAIN
    DMSG FOCUSDIALOG PALETTE CHANGE
    DMSG FOCUSDIALOG PALETTE CIRCLE
    DMSG FOCUSDIALOG PALETTE COPYELEMENT
    DMSG FOCUSDIALOG PALETTE DATABASE
    DMSG FOCUSDIALOG PALETTE DROP
    DMSG FOCUSDIALOG PALETTE ENTERDATA
    DMSG FOCUSDIALOG PALETTE FENCECHANGE
    DMSG FOCUSDIALOG PALETTE FENCECOPY
    DMSG FOCUSDIALOG PALETTE FENCEDELETE
    DMSG FOCUSDIALOG PALETTE FENCEMIRROR
    DMSG FOCUSDIALOG PALETTE FILLET
    DMSG FOCUSDIALOG PALETTE LINESTRING
    DMSG FOCUSDIALOG PALETTE MIRRORELEMENT
    DMSG FOCUSDIALOG PALETTE MODIFY
    DMSG FOCUSDIALOG PALETTE PLACEFENCE
    DMSG FOCUSDIALOG PALETTE POINT
    DMSG FOCUSDIALOG PALETTE POLYGON
    DMSG FOCUSDIALOG PALETTE REFERENCEFILE
    DMSG FOCUSDIALOG PALETTE TEXT
    DMSG FOCUSDIALOG PALETTE THREED
    DMSG FOCUSDIALOG PALETTE VIEWCONTROL
    DMSG FOCUSDIALOG PALETTE WORKSPACE1
    DMSG FOCUSDIALOG PALETTE WORKSPACE2
    DMSG FOCUSDIALOG PALETTE WORKSPACE3
    DMSG FOCUSDIALOG PALETTE WORKSPACE4
    DMSG FOCUSDIALOG PALETTE WORKSPACE5
    DMSG FOCUSDIALOG PALETTE WORKSPACE6
    DMSG FOCUSDIALOG PALETTE WORKSPACE7
    DMSG FOCUSDIALOG PALETTE WORKSPACE8
    DMSG FOCUSDIALOG PALETTE WORKSPACE9
    DMSG FOCUSDIALOG PLOT
    DMSG FOCUSDIALOG PREVIEW
    DMSG FOCUSDIALOG PROPERTIES
    DMSG FOCUSDIALOG READOUT
    DMSG FOCUSDIALOG RENDER
    DMSG FOCUSDIALOG SAVEAS
    DMSG FOCUSDIALOG SAVEIMAGE
    DMSG FOCUSDIALOG SNAPBUTTONS
    DMSG FOCUSDIALOG SNAPS
    DMSG FOCUSDIALOG SNAPVERTICAL
    DMSG FOCUSDIALOG STANDARDALERT
    DMSG FOCUSDIALOG TEXTEDIT
    DMSG FOCUSDIALOG TOOLBOX
    DMSG FOCUSDIALOG TOOLBOX 2DVIEWING
    DMSG FOCUSDIALOG TOOLBOX 3DCONSTRUCT
    DMSG FOCUSDIALOG TOOLBOX 3DDRAWING
    DMSG FOCUSDIALOG TOOLBOX 3DFILLET
    DMSG FOCUSDIALOG TOOLBOX 3DFREEFORM
    DMSG FOCUSDIALOG TOOLBOX 3DMODIFY
    DMSG FOCUSDIALOG TOOLBOX 3DMODSURF
    DMSG FOCUSDIALOG TOOLBOX 3DQUERY
    DMSG FOCUSDIALOG TOOLBOX 3DTOOLS
    DMSG FOCUSDIALOG TOOLBOX 3DVIEWING
    DMSG FOCUSDIALOG TOOLBOX ACS
    DMSG FOCUSDIALOG TOOLBOX ANNOTATE
    DMSG FOCUSDIALOG TOOLBOX ANNOTATION
    DMSG FOCUSDIALOG TOOLBOX ARC
    DMSG FOCUSDIALOG TOOLBOX ATTRIBUTES
    DMSG FOCUSDIALOG TOOLBOX BSPLINE
    DMSG FOCUSDIALOG TOOLBOX CELLS
    DMSG FOCUSDIALOG TOOLBOX CHANGE
    DMSG FOCUSDIALOG TOOLBOX CURVE
    DMSG FOCUSDIALOG TOOLBOX CURVECREATE
    DMSG FOCUSDIALOG TOOLBOX CURVEMODIFY
    DMSG FOCUSDIALOG TOOLBOX DATABASE
    DMSG FOCUSDIALOG TOOLBOX DDDATTACH
    DMSG FOCUSDIALOG TOOLBOX DDDCONSTRAINT
    DMSG FOCUSDIALOG TOOLBOX DDDDRAW
    DMSG FOCUSDIALOG TOOLBOX DDDMODEL
    DMSG FOCUSDIALOG TOOLBOX DDDMODIFY
    DMSG FOCUSDIALOG TOOLBOX DDDPARM
    DMSG FOCUSDIALOG TOOLBOX DDDTOOLS
    DMSG FOCUSDIALOG TOOLBOX DIMANGULAR
    DMSG FOCUSDIALOG TOOLBOX DIMENSION
    DMSG FOCUSDIALOG TOOLBOX DIMLINEAR
    DMSG FOCUSDIALOG TOOLBOX DIMMISC
    DMSG FOCUSDIALOG TOOLBOX DIMRADIAL
    DMSG FOCUSDIALOG TOOLBOX DIMTOOL
    DMSG FOCUSDIALOG TOOLBOX DRFTOOLS
    DMSG FOCUSDIALOG TOOLBOX DROP
    DMSG FOCUSDIALOG TOOLBOX ELLIPSES
    DMSG FOCUSDIALOG TOOLBOX EXTRACT
    DMSG FOCUSDIALOG TOOLBOX FENCE
    DMSG FOCUSDIALOG TOOLBOX FILLET
    DMSG FOCUSDIALOG TOOLBOX GROUPS
    DMSG FOCUSDIALOG TOOLBOX HATCH
    DMSG FOCUSDIALOG TOOLBOX HISTORY
    DMSG FOCUSDIALOG TOOLBOX ISOMETRIC
    DMSG FOCUSDIALOG TOOLBOX JOINTS
    DMSG FOCUSDIALOG TOOLBOX LINE
    DMSG FOCUSDIALOG TOOLBOX LINEAR
    DMSG FOCUSDIALOG TOOLBOX MAIN
    DMSG FOCUSDIALOG TOOLBOX MANIPULATE
    DMSG FOCUSDIALOG TOOLBOX MATCH
    DMSG FOCUSDIALOG TOOLBOX MEASURE
    DMSG FOCUSDIALOG TOOLBOX MODIFY
    DMSG FOCUSDIALOG TOOLBOX PATTERNS
    DMSG FOCUSDIALOG TOOLBOX POINTS
    DMSG FOCUSDIALOG TOOLBOX POLYGONS
    DMSG FOCUSDIALOG TOOLBOX PRIMARY
    DMSG FOCUSDIALOG TOOLBOX REDLINE
    DMSG FOCUSDIALOG TOOLBOX REFERENCE
    DMSG FOCUSDIALOG TOOLBOX SELECTION
    DMSG FOCUSDIALOG TOOLBOX SOLID
    DMSG FOCUSDIALOG TOOLBOX STANDARD
    DMSG FOCUSDIALOG TOOLBOX SURFACE
    DMSG FOCUSDIALOG TOOLBOX TAGS
    DMSG FOCUSDIALOG TOOLBOX TEXT
    DMSG FOCUSDIALOG TOOLBOX VIEWCONTROL
    DMSG FOCUSDIALOG TOOLBOX VIEWGROUPS
    DMSG FOCUSDIALOG TOOLBOX VISUALIZATION
    DMSG FOCUSDIALOG TOOLBOX XYZTXT
    DMSG FOCUSDIALOG TOOLSETTINGS
    DMSG FOCUSDIALOG VIEWRENDERSET
    DMSG FOCUSDIALOG VIEWROTATION
    DMSG FOCUSDIALOG VIEWSETTINGS
    DMSG FOCUSITEM
    DMSG FOCUSPALETTE
    DMSG FOCUSPALETTE 40LINE
    DMSG FOCUSPALETTE 50ARC
    DMSG FOCUSPALETTE 50CELL
    DMSG FOCUSPALETTE 50CHAIN
    DMSG FOCUSPALETTE 50CHANGE
    DMSG FOCUSPALETTE 50CIRCLE
    DMSG FOCUSPALETTE 50CURVE
    DMSG FOCUSPALETTE 50DROP
    DMSG FOCUSPALETTE 50FENCE
    DMSG FOCUSPALETTE 50FILLET
    DMSG FOCUSPALETTE 50LINE
    DMSG FOCUSPALETTE 50MANIPULATE
    DMSG FOCUSPALETTE 50MODIFY
    DMSG FOCUSPALETTE 50POINT
    DMSG FOCUSPALETTE 50POLYGON
    DMSG FOCUSPALETTE 50TEXT
    DMSG FOCUSPALETTE 50VIEWCONTROL
    DMSG FOCUSPALETTE ACS
    DMSG FOCUSPALETTE ARC
    DMSG FOCUSPALETTE CELL
    DMSG FOCUSPALETTE CHAIN
    DMSG FOCUSPALETTE CHANGE
    DMSG FOCUSPALETTE CIRCLE
    DMSG FOCUSPALETTE COPYELEMENT
    DMSG FOCUSPALETTE DATABASE
    DMSG FOCUSPALETTE DROP
    DMSG FOCUSPALETTE ENTERDATA
    DMSG FOCUSPALETTE FENCECHANGE
    DMSG FOCUSPALETTE FENCECOPY
    DMSG FOCUSPALETTE FENCEDELETE
    DMSG FOCUSPALETTE FENCEMIRROR
    DMSG FOCUSPALETTE FILLET
    DMSG FOCUSPALETTE LINESTRING
    DMSG FOCUSPALETTE MIRRORELEMENT
    DMSG FOCUSPALETTE MODIFY
    DMSG FOCUSPALETTE PLACEFENCE
    DMSG FOCUSPALETTE POINT
    DMSG FOCUSPALETTE POLYGON
    DMSG FOCUSPALETTE REFERENCEFILE
    DMSG FOCUSPALETTE TEXT
    DMSG FOCUSPALETTE THREED
    DMSG FOCUSPALETTE VIEWCONTROL
    DMSG FOCUSPALETTE WORKSPACE1
    DMSG FOCUSPALETTE WORKSPACE2
    DMSG FOCUSPALETTE WORKSPACE3
    DMSG FOCUSPALETTE WORKSPACE4
    DMSG FOCUSPALETTE WORKSPACE5
    DMSG FOCUSPALETTE WORKSPACE6
    DMSG FOCUSPALETTE WORKSPACE7
    DMSG FOCUSPALETTE WORKSPACE8
    DMSG FOCUSPALETTE WORKSPACE9
    DMSG GUIMODE
    DMSG GUIMODE MACINTOSH
    DMSG GUIMODE MOTIF
    DMSG GUIMODE WINDOWS
    DMSG HANDLERDEBUG
    DMSG HANDLERDEBUG AFTER
    DMSG HANDLERDEBUG AFTER OFF
    DMSG HANDLERDEBUG AFTER ON
    DMSG HANDLERDEBUG AFTER TOGGLE
    DMSG HANDLERDEBUG BEFORE
    DMSG HANDLERDEBUG BEFORE OFF
    DMSG HANDLERDEBUG BEFORE ON
    DMSG HANDLERDEBUG BEFORE TOGGLE
    DMSG HANDLERDEBUG OFF
    DMSG HANDLERDEBUG ON
    DMSG HANDLERDEBUG TOGGLE
    DMSG ICONBORDERS
    DMSG ICONBORDERS OFF
    DMSG ICONBORDERS ON
    DMSG ICONBORDERS TOGGLE
    DMSG ITEMDEBUG
    DMSG ITEMDEBUG OFF
    DMSG ITEMDEBUG ON
    DMSG ITEMDEBUG TOGGLE
    DMSG NAVIGATION
    DMSG NAVIGATION DIALOG
    DMSG NAVIGATION DIALOG OFF
    DMSG NAVIGATION DIALOG ON
    DMSG NAVIGATION DIALOG TOGGLE
    DMSG NAVIGATION MENUBAR
    DMSG NAVIGATION MENUBAR OFF
    DMSG NAVIGATION MENUBAR ON
    DMSG NAVIGATION MENUBAR TOGGLE
    DMSG OPENMSGFILE
    DMSG REOPENALLDIALOGS
    DMSG RESETFRAMES
    DMSG SHOWVERSIONS
    DMSG SINKALL
    DMSG SINKALL OFF
    DMSG SINKALL ON
    DMSG SINKALL TOGGLE
    DMSG SWITCHUI
    DMSG UPDATENONVIEWCONTENTS
    DMSG VERBOSEDEBUG
    DMSG VERBOSEDEBUG OFF
    DMSG VERBOSEDEBUG ON
    DMSG VERBOSEDEBUG TOGGLE
    DNLCLT
    drop
    drop association
    drop complex
    drop curve
    drop dimension
    drop element
    drop linestyle
    drop mline
    drop pattern
    drop sharecell
    drop string
    drop surface
    drop text
    DUPLICATE
    dwgopen browse seedfile
    dwgopen browse shxpath
    dwgopen dialog open
    dwgsave browse seedfile
    dwgsave browse shxpath
    dwgsave dialog open
    ECHO
    edges batch
    edges default
    edges design
    edges dialog
    edges element
    edges export
    edges fence
    edges preview
    edges process
    edges section export
    edges section preview
    edges set view
    edges set xyresolution
    edges view
    EDIT
    EDIT AE
    EDIT AUTO
    EDIT AUTO DIALOG
    EDIT DIALOGTEXT
    edit englinks tags
    edit flag
    EDIT SINGLE
    EDIT SINGLE DIALOG
    edit tags
    EDIT TEXT
    ELEMENT
    ELEMENT LIST
    EXCHANGEFILE
    EXCHANGEFILE NOUPDATE
    EXCHANGEFILE UPDATE
    EXIT
    EXIT NOUC (*)
    EXIT QUERY (*)
    EXIT RESTART (*)
    EXTEND
    extend curve
    EXTEND ELEMENT
    EXTEND ELEMENT 2
    EXTEND ELEMENT INTERSECTION
    EXTEND LINE
    EXTEND LINE 2
    EXTEND LINE DISTANCE
    EXTEND LINE ICON
    EXTEND LINE INTERSECTION
    EXTEND LINE KEYIN
    extend surface
    extract boundary
    extract bspline boundary
    extract bspline surface boundary
    extract bspline surface isou
    extract bspline surface isov
    extract curve
    extract face
    extract isoline
    extract silhouette curve
    extract surface rule lines
    extract surface trim boundary
    extrude surface region
    FENCE
    FENCE ARRAY
    FENCE ARRAY POLAR
    FENCE ARRAY POLAR DEFAULT (*)
    FENCE ARRAY RECTANGULAR
    FENCE ARRAY RECTANGULAR DEFAULT (*)
    FENCE ATTACH
    FENCE CHANGE
    FENCE CHANGE CLASS
    FENCE CHANGE COLOR
    FENCE CHANGE LEVEL
    FENCE CHANGE LOCK
    FENCE CHANGE STYLE
    FENCE CHANGE SYMBOLOGY
    FENCE CHANGE UNLOCK
    FENCE CHANGE WEIGHT
    FENCE COPY
    FENCE DELETE
    FENCE DETACH
    FENCE DROP
    FENCE DROP ASSOCIATION
    FENCE DROP COMPLEX
    FENCE DROP DIMENSION
    FENCE DROP MLINE
    FENCE FILE
    FENCE FREEZE
    FENCE ICON
    FENCE LOAD
    FENCE MIRROR
    FENCE MIRROR COPY
    FENCE MIRROR COPY HORIZONTAL
    FENCE MIRROR COPY LINE
    FENCE MIRROR COPY VERTICAL
    FENCE MIRROR ORIGINAL
    FENCE MIRROR ORIGINAL HORIZONTAL
    FENCE MIRROR ORIGINAL LINE
    FENCE MIRROR ORIGINAL VERTICAL
    fence mode stretch
    FENCE MOVE
    FENCE OLDROTATE (*)
    FENCE OLDROTATE COPY (*)
    FENCE OLDROTATE ORIGINAL  (*)
    FENCE OLDSCALE (*)
    FENCE OLDSCALE COPY (*)
    FENCE OLDSCALE ORIGINAL (*)
    FENCE OLDSPIN (*)
    FENCE OLDSPIN COPY (*)
    FENCE OLDSPIN ORIGINAL (*)
    FENCE REPORT
    fence rotate
    fence rotate copy
    fence rotate original
    fence rotate points
    fence rotate points copy
    fence rotate points original
    fence scale
    fence scale copy
    fence scale original
    fence scale points
    fence scale points copy
    fence scale points original
    fence selection append
    fence selection new
    fence selection remove
    FENCE SEPARATE
    fence spin
    fence spin copy
    fence spin original
    FENCE STRETCH
    FENCE SURFACE
    FENCE SURFACE PROJECTION
    FENCE SURFACE REVOLUTION (*)
    FENCE SURFACE REVOLUTION DEFAULT (*)
    FENCE THAW
    FENCE TRANSFORM
    FENCE WSET
    FENCE WSET ADD
    FENCE WSET COPY
    FILEDESIGN
    FILLET
    fillet bspline surface
    fillet bspline surface modify
    fillet bspline surface nomodify
    fillet bspline surface single
    fillet curve
    FILLET ICON
    FILLET MODIFY
    FILLET NOMODIFY
    FILLET SINGLE
    fillet surface
    filters element settings dialog
    FIND
    FIT
    FIT ACTIVE
    FIT ALL
    fit raster
    FIT REFERENCE
    FIT TOFENCE
    fit view
    fit view extended
    flag update
    FLUSH
    follow webtag
    FORMS
    FORMS DISPLAY
    FORMS MODE (*)
    FORMS MODE DIALOG (*)
    FORMS MODE NONE (*)
    FORMS MODE TEXT (*)
    FORMS OFF
    FORMS ON
    FREE
    FREEZE
    GENERATE
    GETCLR (*)
    GROUP
    GROUP ADD
    GROUP DROP
    GROUP HOLES
    GROUP SELECTION
    hatch
    hatch difference
    hatch element
    hatch fence
    hatch flood
    hatch icon
    hatch intersection
    hatch points
    hatch union
    HELP
    HELP CONTEXT (*)
    history ccrevdetails
    history commit
    history import
    history initialize
    history restore
    history show
    hline extract
    hline palette
    IDENTIFY
    IDENTIFY CELL
    IDENTIFY TEXT
    IGEN (*)
    IGEN LOAD (*)
    impose bspline boundary
    impose bspline surface boundary
    INCLUDE
    INCREMENT
    INCREMENT ED
    INCREMENT TEXT
    INDEX
    INSERT
    INSERT DIMVERTEX
    INSERT VERTEX
    intersect bspline surface
    intersect bspline surface modify
    intersect curve surface
    IUPDATE
    IUPDATE 1
    IUPDATE 2
    IUPDATE 3
    IUPDATE 4
    IUPDATE 5
    IUPDATE 6
    IUPDATE 7
    IUPDATE 8
    IUPDATE ALL
    IUPDATE BOTH
    IUPDATE FENCE
    IUPDATE FENCE INSIDE
    IUPDATE FENCE OUTSIDE
    IUPDATE FILE
    IUPDATE GRID
    IUPDATE LEFT
    IUPDATE RIGHT
    IUPDATE VIEW
    JAVA
    JAVA  G
    JMDL
    JMDL  G
    join corner
    join cross
    join cross closed
    join cross merge
    join cross open
    join tee
    join tee closed
    join tee merge
    join tee open
    JUSTIFY
    JUSTIFY CENTER
    JUSTIFY LEFT
    JUSTIFY RIGHT
    label line
    LEVEL
    LEVEL CREATE
    LEVEL DELETE
    level delete unused (**)
    LEVEL DRAW
    LEVEL FILTER
    LEVEL FILTER CREATE
    LEVEL FILTER DELETE
    LEVEL FILTER GROUP
    LEVEL LIBRARY
    LEVEL LIBRARY ATTACH
    LEVEL LIBRARY DETACH
    LEVEL LIBRARY EXPORT
    LEVEL LIBRARY IMPORT
    LEVEL LIBRARY SYNC (*)
    LEVEL SET (*)
    LEVEL SET FROZEN (*)
    LEVEL SET FROZEN OFF (*)
    LEVEL SET FROZEN ON (*)
    LEVEL SET FROZEN TOGGLE (*)
    LEVEL TABLE (*)
    LEVEL TABLE READONLY (*)
    LEVEL USAGE
    levelmanager change level
    levelmanager dialog close
    levelmanager dialog open
    levelmanager filter new list
    levelmanager filter new tree
    levelmanager filter recall
    levelmanager filter rename list
    levelmanager filter rename tree
    levelmanager filter save
    levelmanager filter saveas
    levelmanager level delete list
    levelmanager level delete tree
    levelmanager level lockbyelem
    levelmanager level new
    levelmanager level offbyelem
    levelmanager level offexceptelem
    levelmanager level settarget
    levelmanager level settarget list
    levelmanager level settarget tree
    levelmanager level unlockbyelem
    levelmanager library attach
    levelmanager library detach
    levelmanager library export
    levelmanager library import
    levelmanager save
    light apply
    light clear
    light define
    light delete
    light dolly
    light edit
    light move
    light place
    light position
    light scan
    light target
    line surface intersections
    linestyle edit
    linestyle library
    linestyle settings
    LOAD
    LOAD DA
    LOAD DAICON
    LOCELE
    LOCK
    LOCK ACS
    LOCK ACS OFF
    LOCK ACS ON
    LOCK ACS TOGGLE
    LOCK ACSPERPENDICULAR
    LOCK ACSPERPENDICULAR OFF
    LOCK ACSPERPENDICULAR ON
    LOCK ACSPERPENDICULAR TOGGLE
    LOCK ANGLE
    LOCK ANGLE OFF
    LOCK ANGLE ON
    LOCK ANGLE TOGGLE
    LOCK ASSOCIATION
    LOCK ASSOCIATION OFF
    LOCK ASSOCIATION ON
    LOCK ASSOCIATION TOGGLE
    LOCK AXIS
    LOCK AXIS OFF
    LOCK AXIS ON
    LOCK AXIS TOGGLE
    LOCK BORESITE
    LOCK BORESITE OFF
    LOCK BORESITE ON
    LOCK BORESITE TOGGLE
    LOCK CELLSTRETCH
    LOCK CELLSTRETCH OFF
    LOCK CELLSTRETCH ON
    LOCK CELLSTRETCH TOGGLE
    LOCK CONSTRUCTION
    LOCK CONSTRUCTION OFF
    LOCK CONSTRUCTION ON
    LOCK CONSTRUCTION TOGGLE
    LOCK DEPTH
    LOCK DEPTH OFF
    LOCK DEPTH ON
    LOCK DEPTH TOGGLE
    LOCK FENCE
    LOCK FENCE CLIP
    LOCK FENCE INSIDE
    LOCK FENCE OVERLAP
    LOCK FENCE VOID
    LOCK FENCE VOID CLIP
    LOCK FENCE VOID OUTSIDE
    LOCK FENCE VOID OVERLAP
    LOCK GGROUP
    LOCK GGROUP OFF
    LOCK GGROUP ON
    LOCK GGROUP TOGGLE
    LOCK GRID
    LOCK GRID OFF
    LOCK GRID ON
    LOCK GRID TOGGLE
    LOCK ISOMETRIC
    LOCK ISOMETRIC OFF
    LOCK ISOMETRIC ON
    LOCK ISOMETRIC TOGGLE
    LOCK LEVEL
    LOCK LEVEL OFF
    LOCK LEVEL ON
    LOCK LEVEL TOGGLE
    LOCK SCALE
    LOCK SCALE OFF
    LOCK SCALE ON
    LOCK SCALE TOGGLE
    LOCK SELECTION
    LOCK SELECTION OFF
    LOCK SELECTION ON
    LOCK SELECTION TOGGLE
    LOCK SNAP
    LOCK SNAP ACS
    LOCK SNAP ACS OFF
    LOCK SNAP ACS ON
    LOCK SNAP ACS TOGGLE
    LOCK SNAP BISECTOR
    LOCK SNAP CENTER
    LOCK SNAP CONSTRUCTION (*)
    LOCK SNAP CONSTRUCTION OFF (*)
    LOCK SNAP CONSTRUCTION ON (*)
    LOCK SNAP CONSTRUCTION TOGGLE (*)
    LOCK SNAP INTERSECTION
    LOCK SNAP KEYPOINT
    LOCK SNAP MIDPOINT
    LOCK SNAP MODE
    LOCK SNAP NEAREST
    LOCK SNAP OFF
    LOCK SNAP ON
    LOCK SNAP ORIGIN
    lock snap parallel
    lock snap perpendicular
    lock snap pointon
    LOCK SNAP PROJECT
    lock snap ptperpendicular
    lock snap pttangent
    lock snap ptthrough
    lock snap tangency
    LOCK TEXTNODE
    LOCK TEXTNODE OFF
    LOCK TEXTNODE ON
    LOCK TEXTNODE TOGGLE
    LOCK UNIT
    LOCK UNIT OFF
    LOCK UNIT ON
    LOCK UNIT TOGGLE
    MACRO
    MARK
    match color
    match curve
    match dimension
    match element
    match icon
    match level
    match mline
    match palette
    match pattern
    match style
    match surface
    match symbology
    match text
    match unload
    match weight
    material apply
    material assign
    material assign delete
    material assign edit
    material assign palette
    material assign preview
    material assign select
    material assign table default
    material assign table open
    material assign table save
    material assign table saveas
    material attribute attach
    material attribute delete
    material attribute show
    material edit
    material environment clear
    material environment set all
    material environment set back
    material environment set bottom
    material environment set front
    material environment set left
    material environment set right
    material environment set top
    material palette add
    material palette copy
    material palette delete
    material palette import
    MATRIX
    MATRIX CELL
    MATRIX CELL DEFAULT (*)
    MC
    MDL
    MDL COMMAND
    MDL DEBUG
    MDL DLOGLOAD (*)
    MDL HEAP (*)
    MDL KEYIN (*)
    MDL LOAD
    MDL METHOD (*)
    MDL SILENTLOAD (*)
    MDL SILENTUNLOAD (*)
    MDL UNLOAD
    measure
    measure angle
    measure area
    measure area difference
    measure area element
    measure area fence
    measure area flood
    measure area intersection
    measure area points
    measure area union
    measure display centroid
    measure display moments
    measure display principals
    measure display radii
    measure distance along
    measure distance icon
    measure distance minimum
    measure distance perpendicular
    measure distance points
    measure distance surface
    measure length
    measure palette
    measure print
    measure radius
    measure save
    measure volume
    MIRROR
    MIRROR COPY
    MIRROR COPY LINE
    MIRROR ICON
    MIRROR ORIGINAL
    mline edit cap
    mline edit profile
    mline partial delete
    model choose
    model copy
    model create
    model delete
    model dump
    model edit_dimension
    model flip
    model gg_update
    model import
    model info
    model isolate off
    model isolate on
    model lcs
    model manager
    model merge
    model mirror
    model modify
    model plan
    model properties
    model simulate
    model update
    MODIFY
    MODIFY ARC
    MODIFY ARC ANGLE
    MODIFY ARC AXIS
    MODIFY ARC RADIUS
    modify bspline curve
    modify bspline lock normal
    modify bspline lock off
    modify bspline lock tangent
    modify bspline surface
    modify clip add
    modify clip delete
    modify dimension loc
    modify element
    MODIFY FENCE
    MODIFY FENCE ICON
    modify linestyle
    modify linestyle dashscale
    modify linestyle endwidth
    modify linestyle gapscale
    modify linestyle icon
    modify linestyle scale
    modify linestyle shift
    modify linestyle startwidth
    modify linestyle width
    modify text
    modify thickness
    modify trim
    modify view
    MOVE
    MOVE ACS
    MOVE DOWN
    MOVE ELEMENT
    move extended
    MOVE FENCE
    MOVE ICON
    MOVE LEFT
    MOVE PARALLEL
    MOVE PARALLEL DISTANCE
    MOVE PARALLEL ICON
    MOVE PARALLEL KEYIN
    move parallel offset
    MOVE RIGHT
    MOVE UP
    namedview delete
    namedview import
    namedview properties
    namedview save
    NE (*)
    NEWFILE
    NOCOMMAND
    NOECHO
    NOTRANS (*)
    NULL
    OLDSCALE (*)
    OLDSCALE COPY (*)
    OLDSCALE ICON (*)
    OLDSPIN (*)
    OLDSPIN COPY (*)
    olecntr edit
    olecntr insert
    olecntr pastemethod
    olecntr update
    orient surfaces
    PAGE
    PAGE SETUP (*)
    palette 3dfreeform
    palette changesurface splines
    palette derived splines
    palette frame splines
    palette spacecurve splines
    palette surface splines
    pan view
    particletrace cleardatabase
    particletrace delete all
    particletrace resetdefaults
    particletrace switchinterface
    pattern
    pattern area
    pattern area difference
    pattern area element
    pattern area fence
    pattern area flood
    pattern area icon
    pattern area intersection
    pattern area points
    pattern area union
    pattern line
    pattern line element
    pattern line icon
    pattern line multiple
    pattern line scale
    pattern line single
    pattern mode
    pattern mode difference
    pattern mode element
    pattern mode fence
    pattern mode flood
    pattern mode intersection
    pattern mode points
    pattern mode union
    pattern palette
    PAUSE
    PLACE
    PLACE ARC
    PLACE ARC CENTER
    PLACE ARC EDGE
    place arc edge constrained
    place arc icon
    PLACE ARC RADIUS
    PLACE ARC TANGENT (*)
    place arrow marker
    PLACE BLOCK
    PLACE BLOCK ICON
    PLACE BLOCK ISOMETRIC
    PLACE BLOCK ORTHOGONAL
    PLACE BLOCK ROTATED
    place bspline
    place bspline curve
    place bspline curve catmullrom
    place bspline curve leastsquares
    place bspline curve points
    place bspline curve poles
    place bspline curve surface
    place bspline rho
    place bspline surface
    place bspline surface catmullrom
    place bspline surface leastsquares
    place bspline surface points
    place bspline surface poles
    place callout bubble
    place callout leader
    PLACE CELL
    PLACE CELL ABSOLUTE
    PLACE CELL ABSOLUTE TMATRX
    PLACE CELL ICON
    PLACE CELL INTERACTIVE
    PLACE CELL INTERACTIVE ABSOLUTE
    PLACE CELL INTERACTIVE RELATIVE
    PLACE CELL RELATIVE
    PLACE CELL RELATIVE TMATRX
    PLACE CIRCLE
    PLACE CIRCLE CENTER
    place circle center constrained
    place circle diameter
    PLACE CIRCLE EDGE
    place circle edge constrained
    place circle icon
    PLACE CIRCLE ISOMETRIC
    PLACE CIRCLE RADIUS
    place composite
    PLACE CONE
    place cone icon
    PLACE CONE RADIUS
    PLACE CONE RIGHT
    PLACE CONE SKEWED
    place conic
    PLACE CURVE
    place curve icon
    PLACE CURVE PICON (*)
    PLACE CURVE POINT
    PLACE CURVE SPACE
    PLACE CURVE STREAM
    PLACE CYLINDER
    PLACE CYLINDER CAPPED
    place cylinder icon
    PLACE CYLINDER RADIUS
    PLACE CYLINDER RIGHT
    PLACE CYLINDER SKEWED
    PLACE CYLINDER UNCAPPED
    place detail marker
    PLACE DIALOGTEXT
    PLACE DIALOGTEXT ABOVE
    PLACE DIALOGTEXT ALONG
    PLACE DIALOGTEXT BELOW
    PLACE DIALOGTEXT FITTED
    PLACE DIALOGTEXT FVI
    PLACE DIALOGTEXT ICON
    PLACE DIALOGTEXT ON
    PLACE DIALOGTEXT TMATRIX
    PLACE DIALOGTEXT VI
    PLACE ELLIPSE
    PLACE ELLIPSE CENTER
    place ellipse center constrained
    PLACE ELLIPSE EDGE
    place ellipse edge constrained
    PLACE ELLIPSE FOURTH (*)
    PLACE ELLIPSE HALF
    place ellipse icon
    PLACE ELLIPSE QUARTER
    PLACE FENCE
    PLACE FENCE ACTIVE
    PLACE FENCE ALLFILES
    PLACE FENCE BLOCK
    PLACE FENCE CIRCLE
    PLACE FENCE DESIGN
    PLACE FENCE ELEMENT
    PLACE FENCE FROMSHAPE
    PLACE FENCE ICON (*)
    PLACE FENCE SHAPE
    PLACE FENCE UNIVERSE
    PLACE FENCE VIEW
    place flag
    place generic leader
    place helix
    place image
    PLACE LINE
    PLACE LINE ANGLE
    place line constrained
    PLACE LSTRING
    place lstring constrained
    PLACE LSTRING POINT
    PLACE LSTRING SPACE
    PLACE LSTRING STREAM
    PLACE MLINE
    place mline constrained
    PLACE NODE
    PLACE NODE ICON
    PLACE NODE TMATRIX
    PLACE NODE VIEW
    place note multi
    PLACE PARABOLA
    place parabola endpoints
    PLACE PARABOLA HORIZONTAL
    PLACE PARABOLA HORIZONTAL MODIFY
    PLACE PARABOLA HORIZONTAL NOMODIFY
    PLACE PARABOLA ICON
    PLACE PARABOLA MODIFY
    PLACE PARABOLA NOMODIFY
    PLACE POINT
    PLACE POINT STRING
    PLACE POINT STRING CONTINUOUS
    PLACE POINT STRING DISJOINT
    PLACE POLYGON
    PLACE POLYGON CIRCUMSCRIBED
    PLACE POLYGON EDGE
    PLACE POLYGON ICON
    PLACE POLYGON INSCRIBED
    PLACE REVCLOUD ELEMENT
    place section marker
    PLACE SHAPE
    PLACE SHAPE ICON
    PLACE SHAPE ORTHOGONAL
    PLACE SLAB
    place slab icon
    place smartline
    place smartline arc
    PLACE SPHERE
    place sphere icon
    place spiral
    place spiral angle
    place spiral endpoints
    place spiral length
    place surface
    place symbol
    PLACE TERMINATOR
    PLACE TEXT
    PLACE TEXT ABOVE
    PLACE TEXT ALONG
    PLACE TEXT BELOW
    PLACE TEXT FITTED
    PLACE TEXT FVI
    PLACE TEXT ICON
    PLACE TEXT ON
    PLACE TEXT TMATRIX
    PLACE TEXT VI
    place title text
    place torus
    place wedge
    PLOT (*)
    POINT
    POINT ABSOLUTE
    POINT ACSABSOLUTE
    POINT ACSDELTA
    POINT DEFAULT
    POINT DELTA
    POINT DISTANCE
    point keyin
    point keyin multiple
    point keyin single
    POINT VDELTA
    popcalc variable delete
    popcalc variable save
    popcalc variable show
    POPMENU
    popset off
    popset on
    popset toggle
    powerselector
    powerselector all
    powerselector area
    powerselector area block
    powerselector area inside
    powerselector area overlap
    powerselector area shape
    powerselector area shape inside
    powerselector area shape overlap
    powerselector deselect
    powerselector line
    powerselector mode
    powerselector mode add
    powerselector mode inverse
    powerselector mode new
    powerselector mode remove
    powerselector single
    PREVIEW
    PRINT
    project trim
    punch surface region
    QU (*)
    QUIT
    QUIT NOUC (*)
    QUIT QUERY (*)
    QUIT RESTART (*)
    QVISION (*)
    QVISION CLEARDAG (*)
    radiosity cleardatabase
    radiosity fixedadaptation
    radiosity query
    radiosity select adaptationlevel
    radiosity set adaptationlevel
    radiosity set fixedadaptation off
    radiosity set fixedadaptation on
    radiosity set meterspermu
    radiosity set shootinterior off
    radiosity set shootinterior on
    radiosity shootinterior
    raster attach fixed
    raster attach interactive
    raster attachurl
    raster clip boundary
    raster clip mask
    raster detach
    raster detach all
    raster display
    raster display off
    raster display on
    raster display toggle
    raster fit
    raster fitall
    raster foreground color
    raster mirror horizontal
    raster mirror vertical
    raster modify
    raster move
    raster openreadonly get
    raster openreadonly setoff
    raster openreadonly seton
    raster preview fixed
    raster preview interactive
    raster refresh
    raster reload
    raster rotate 180
    raster rotate 270
    raster rotate 90
    raster save
    raster saveauto get
    raster silent off
    raster silent on
    raster silent toggle
    raster warp affine
    raster warp helmert
    raytrace adjust
    raytrace boxfilter
    raytrace cleardatabase
    raytrace defaults
    raytrace environment
    raytrace extents
    raytrace fresnel
    raytrace jitter
    raytrace limitmemory
    raytrace newenv
    raytrace quickdisplay
    raytrace reflections
    raytrace renderallobjects
    raytrace resetdefaults
    raytrace scale
    raytrace set adjust off
    raytrace set adjust on
    raytrace set boxfilter off
    raytrace set boxfilter on
    raytrace set colorclip off
    raytrace set colorclip on
    raytrace set contrast
    raytrace set contribution
    raytrace set environment off
    raytrace set environment on
    raytrace set extents off
    raytrace set extents on
    raytrace set filterheight
    raytrace set filterwidth
    raytrace set fresnel off
    raytrace set fresnel on
    raytrace set jitter off
    raytrace set jitter on
    raytrace set limitmemory off
    raytrace set limitmemory on
    raytrace set maxreflections
    raytrace set maxsamples
    raytrace set maxtransparency
    raytrace set memorylimit
    raytrace set meterspermu
    raytrace set minsamples
    raytrace set quickdisplay off
    raytrace set quickdisplay on
    raytrace set reflections off
    raytrace set reflections on
    raytrace set renderscale off
    raytrace set renderscale on
    raytrace set scalefactor
    raytrace set shadows off
    raytrace set shadows on
    raytrace set statistics off
    raytrace set statistics on
    raytrace set stereo off
    raytrace set stereo on
    raytrace set transparency off
    raytrace set transparency on
    raytrace shadows
    raytrace statistics
    raytrace stereo
    raytrace subdivideallobjects
    raytrace transparency
    READONLYERR (*)
    redfile off
    redfile on
    redfile toggle
    REDO
    REDO ELEMENT (*)
    REFERENCE
    REFERENCE ATTACH
    REFERENCE ATTACH DEFAULT (*)
    REFERENCE CLIP
    REFERENCE CLIP BACK
    REFERENCE CLIP BOUNDARY
    REFERENCE CLIP DELETE
    REFERENCE CLIP FRONT
    REFERENCE CLIP MASK
    REFERENCE CLIP ROTATE (*)
    REFERENCE CLIP ROTATE OFF (*)
    REFERENCE CLIP ROTATE ON (*)
    REFERENCE CLIP ROTATE TOGGLE (*)
    REFERENCE COPY
    REFERENCE DETACH
    REFERENCE DISPLAY
    reference display design
    REFERENCE DISPLAY OFF
    REFERENCE DISPLAY ON
    reference display raster
    REFERENCE DISPLAY TOGGLE
    REFERENCE EXCHANGE
    REFERENCE FIT
    REFERENCE GROUP
    REFERENCE GROUP ADD
    REFERENCE GROUP DROP
    REFERENCE LEVELS
    REFERENCE LEVELS OFF
    REFERENCE LEVELS ON
    REFERENCE LEVELS TOGGLE
    REFERENCE LOCATE
    REFERENCE LOCATE OFF
    REFERENCE LOCATE ON
    REFERENCE LOCATE TOGGLE
    reference merge
    REFERENCE MIRROR
    REFERENCE MIRROR HORIZONTAL
    REFERENCE MIRROR VERTICAL
    REFERENCE MOVE
    REFERENCE PRESENTATION
    REFERENCE RELOAD
    REFERENCE ROTATE
    REFERENCE ROTATE ANGLE
    REFERENCE ROTATE POINTS
    REFERENCE SCALE
    REFERENCE SCALE ABSOLUTE
    REFERENCE SCALE FACTOR
    REFERENCE SCALE POINTS
    REFERENCE SNAP
    REFERENCE SNAP OFF
    REFERENCE SNAP ON
    REFERENCE SNAP TOGGLE
    REFERENCE UPDATE
    remove bspline boundary all
    remove bspline boundary single
    remove faces
    RENAME
    RENAME CELL
    RENAME CELL DEFAULT (*)
    RENDER
    RENDER ALL
    RENDER ALL CONSTANT
    RENDER ALL FILLED
    RENDER ALL HIDDEN
    RENDER ALL PHONG
    RENDER ALL SMOOTH
    RENDER ALL WIREMESH
    RENDER ELEMENT
    RENDER ELEMENT CONSTANT
    RENDER ELEMENT FILLED
    RENDER ELEMENT HIDDEN
    RENDER ELEMENT PHONG
    RENDER ELEMENT SMOOTH
    RENDER ELEMENT WIREMESH
    RENDER FENCE
    RENDER FENCE CONSTANT
    RENDER FENCE FILLED
    RENDER FENCE HIDDEN
    RENDER FENCE PHONG
    render fence raytrace
    RENDER FENCE SMOOTH
    RENDER FENCE WIREMESH
    RENDER ICON
    render log delete
    render log off
    render log on
    render statistics
    RENDER VIEW
    RENDER VIEW CONSTANT
    RENDER VIEW CONSTANT ANTIALIAS
    RENDER VIEW CONSTANT STEREO
    RENDER VIEW FILLED
    RENDER VIEW FILLED ANTIALIAS
    RENDER VIEW FILLED STEREO
    RENDER VIEW HIDDEN
    RENDER VIEW HIDDEN ANTIALIAS
    RENDER VIEW HIDDEN STEREO
    render view particletrace
    render view particletrace antialias
    render view particletrace stereo
    RENDER VIEW PHONG
    RENDER VIEW PHONG ANTIALIAS
    RENDER VIEW PHONG STEREO
    render view radiosity
    render view radiosity antialias
    render view radiosity stereo
    render view raytrace
    render view raytrace antialias
    render view raytrace stereo
    RENDER VIEW SMOOTH
    RENDER VIEW SMOOTH ANTIALIAS
    RENDER VIEW SMOOTH STEREO
    RENDER VIEW WIREMESH
    REPLACE
    REPLACE CELL
    replace cells
    replace cells extended
    RESET
    RESOURCEFILE (*)
    RESOURCEFILE OPEN (*)
    REVIEW
    review tags
    ROTATE
    ROTATE 3PTS
    ROTATE ACS
    ROTATE ACS ABSOLUTE
    ROTATE ACS ABSOLUTE DEFAULT (*)
    ROTATE ACS RELATIVE
    ROTATE ACS RELATIVE DEFAULT (*)
    rotate copy
    rotate icon
    ROTATE OLDCOPY (*)
    ROTATE OLDICON (*)
    ROTATE OLDORIGINAL (*)
    rotate original
    rotate points
    rotate points copy
    rotate standard
    ROTATE VIEW
    ROTATE VIEW ABSOLUTE
    ROTATE VIEW ELEMENT
    rotate view extended
    ROTATE VIEW POINTS
    ROTATE VIEW RELATIVE
    ROTATE VMATRX
    SAVE
    SAVE ACS
    SAVE DESIGN
    SAVE FUNCTION KEY
    SAVE IMAGE
    SAVE VIEW
    scale
    scale copy
    scale icon
    scale original
    scale points
    scale points copy
    SELECT
    SELECT CELL
    SELECT CELL ABSOLUTE
    SELECT CELL ABSOLUTE TMATRX
    SELECT CELL ICON
    SELECT CELL RELATIVE
    SELECT CELL RELATIVE TMATRX
    SELVIEW
    SET
    SET ACSDISPLAY
    SET ACSDISPLAY OFF
    SET ACSDISPLAY ON
    SET ACSDISPLAY TOGGLE
    SET AUTOPAN
    SET AUTOPAN OFF
    SET AUTOPAN ON
    SET AUTOPAN TOGGLE
    SET AUXINPUT (*)
    SET AUXINPUT OFF (*)
    SET AUXINPUT ON (*)
    SET AUXINPUT TOGGLE (*)
    SET BACKGROUND
    SET BACKGROUND OFF
    SET BACKGROUND ON
    SET BACKGROUND TOGGLE
    SET BUTTON
    SET CAMERA
    SET CAMERA DEFINITION
    SET CAMERA DISTANCE
    SET CAMERA ICON
    SET CAMERA LENS
    SET CAMERA LENS ANGLE
    SET CAMERA LENS EXTRAWIDE
    SET CAMERA LENS FISHEYE
    SET CAMERA LENS LENGTH
    SET CAMERA LENS NORMAL
    SET CAMERA LENS PORTRAIT
    SET CAMERA LENS TELEPHOTO
    SET CAMERA LENS TELESCOPIC
    SET CAMERA LENS WIDE
    SET CAMERA OFF
    SET CAMERA ON
    SET CAMERA POSITION
    SET CAMERA TARGET
    SET CELLS
    SET CELLS OFF
    SET CELLS ON
    SET CELLS TOGGLE
    SET COMPATIBLE
    SET COMPATIBLE DIMENSION
    SET COMPATIBLE DIMENSION OFF
    SET COMPATIBLE DIMENSION ON
    SET COMPATIBLE DIMENSION TOGGLE
    SET COMPATIBLE MLINE
    SET COMPATIBLE MLINE OFF
    SET COMPATIBLE MLINE ON
    SET COMPATIBLE MLINE TOGGLE
    SET COMPATIBLE OFF
    SET COMPATIBLE ON
    SET CONFIRM
    SET CONFIRM OFF
    SET CONFIRM ON
    SET CONFIRM TOGGLE
    SET CONSTRUCT
    SET CONSTRUCT OFF
    SET CONSTRUCT ON
    SET CONSTRUCT TOGGLE
    SET CONTROL
    SET COORDINATES
    SET COORDINATES OFF
    SET COORDINATES ON
    SET COORDINATES TOGGLE
    SET CURSOR
    SET CURSOR FULL
    SET CURSOR ISOMETRIC
    SET CURSOR ORTHOGONAL
    SET CURSOR SMALL
    SET CURSOR TOGGLE
    SET CURVES
    SET CURVES FAST
    SET CURVES SLOW
    SET CURVES TOGGLE
    SET DATABASE
    SET DDEPTH
    SET DDEPTH ABSOLUTE
    SET DDEPTH RELATIVE
    SET DEBUG (*)
    set default tolerance
    SET DELETE
    SET DELETE OFF
    SET DELETE ON
    SET DELETE TOGGLE
    SET DEPTHCUE
    SET DEPTHCUE OFF
    SET DEPTHCUE ON
    SET DEPTHCUE TOGGLE
    SET DIMENSION
    SET DIMENSION OFF
    SET DIMENSION ON
    SET DIMENSION TOGGLE
    set drafting parameters
    SET DYNAMIC
    SET DYNAMIC OFF
    SET DYNAMIC ON
    SET DYNAMIC TOGGLE
    SET DYNOSIZE (*)
    SET ED
    SET ED OFF
    SET ED ON
    SET ED TOGGLE
    SET EDCHAR
    SET FILL
    SET FILL OFF
    SET FILL ON
    SET FILL TOGGLE
    SET FONT
    SET FONT FAST
    SET FONT MODE (*)
    SET FONT MODE OFF (*)
    SET FONT MODE ON (*)
    SET FONT MODE TOGGLE
    SET FONT OFF
    SET FONT ON
    SET FONT SLOW
    SET FONT TOGGLE
    SET FUNCTION
    SET GRID
    SET GRID OFF
    SET GRID ON
    SET GRID TOGGLE
    SET HELP (*)
    SET HELP OFF (*)
    SET HELP ON (*)
    SET HELP TOGGLE (*)
    SET HILITE
    SET HILITE BLACK
    SET HILITE BLUE
    SET HILITE CYAN
    SET HILITE DGREY
    SET HILITE GREEN
    SET HILITE LGREY
    SET HILITE MAGENTA
    SET HILITE RED
    SET HILITE WHITE
    SET HILITE YELLOW
    set isolines
    SET ISOPLANE
    SET ISOPLANE ALL
    SET ISOPLANE LEFT
    SET ISOPLANE RIGHT
    SET ISOPLANE TOP
    SET JAVACHILD (*)
    SET JAVACHILD OFF (*)
    SET JAVACHILD ON (*)
    SET JAVACHILD TOGGLE (*)
    SET LEVELS
    SET LEVELS OFF
    SET LEVELS ON
    SET LINEFILL (*)
    SET LINEFILL OFF (*)
    SET LINEFILL ON (*)
    SET LINEFILL TOGGLE (*)
    SET LINEWIDTH (*)
    SET LINEWIDTH OFF (*)
    SET LINEWIDTH ON (*)
    SET LINEWIDTH TOGGLE (*)
    SET LOCATE
    SET LVLSYMB
    SET LVLSYMB OFF
    SET LVLSYMB ON
    SET LVLSYMB TOGGLE
    SET MAXGRID
    SET MIRTEXT
    SET MIRTEXT OFF
    SET MIRTEXT ON
    SET MIRTEXT TOGGLE
    set modifywarning
    set modifywarning off
    set modifywarning on
    SET NODES
    SET NODES OFF
    SET NODES ON
    SET NODES TOGGLE
    SET ORIENTATION
    SET ORIENTATION OFF
    SET ORIENTATION ON
    SET ORIENTATION TOGGLE
    SET OVERVIEW (*)
    SET OVERVIEW LEFT (*)
    SET OVERVIEW OFF (*)
    SET OVERVIEW ON (*)
    SET OVERVIEW RIGHT (*)
    SET OVERVIEW TOGGLE (*)
    SET PARSEALL
    SET PARSEALL OFF
    SET PARSEALL ON
    SET PARSEALL TOGGLE
    SET PATTERN
    SET PATTERN OFF
    SET PATTERN ON
    SET PATTERN TOGGLE
    SET PLOTTER (*)
    SET PRINTER
    SET PROMPT
    set qvision bezier
    set qvision facet
    set qvision surf
    SET RANGE (*)
    SET RANGE OFF (*)
    SET RANGE ON (*)
    SET RANGE TOGGLE (*)
    SET RASTERTEXT (*)
    SET RASTERTEXT OFF (*)
    SET RASTERTEXT ON (*)
    SET RASTERTEXT TOGGLE (*)
    SET REFBOUND
    SET REFBOUND OFF
    SET REFBOUND ON
    SET REFBOUND TOGGLE
    SET REFCLIP
    SET REFCLIP FAST
    SET REFCLIP SLOW
    SET REFCLIP TOGGLE
    SET RMDEBUG (*)
    SET SAVEAREA (*)
    SET SCANNER (*)
    SET SCANNER NEW (*)
    SET SCANNER OLD (*)
    SET SHARECELL
    SET SHARECELL OFF
    SET SHARECELL ON
    SET SHARECELL TOGGLE
    SET SMALLTEXT
    SET STACKFRACTIONS
    SET STACKFRACTIONS OFF
    SET STACKFRACTIONS ON
    SET STACKFRACTIONS TOGGLE
    SET STREAM
    SET STREAM OFF
    SET STREAM ON
    SET STREAM TOGGLE
    SET TEXT
    SET TEXT FAST
    SET TEXT MODE (*)
    SET TEXT MODE OFF (*)
    SET TEXT MODE ON (*)
    SET TEXT MODE TOGGLE (*)
    SET TEXT OFF
    SET TEXT ON
    SET TEXT SLOW
    SET TEXT TOGGLE
    set tolerance
    SET TPMODE
    SET TPMODE ACSDELTA
    SET TPMODE ACSLOCATE
    SET TPMODE ANGLE2
    SET TPMODE DELTA
    SET TPMODE DISTANCE
    SET TPMODE LOCATE
    SET TPMODE VDELTA
    SET UNDO
    SET UNDO OFF
    SET UNDO ON
    SET UNDO TOGGLE
    SET VIEW
    SET VIEW CONSTANT
    SET VIEW FILLED
    SET VIEW HIDDEN
    SET VIEW PHONG
    SET VIEW SMOOTH
    SET VIEW WIREFRAME
    SET VIEW WIREMESH
    SET WEIGHT
    SET WEIGHT OFF
    SET WEIGHT ON
    SET WEIGHT TOGGLE
    SET XOR
    SET XOR BLACK
    SET XOR BLUE
    SET XOR CYAN
    SET XOR DGREY
    SET XOR GREEN
    SET XOR LGREY
    SET XOR MAGENTA
    SET XOR RED
    SET XOR WHITE
    SET XOR YELLOW
    SET XORDYNAMICS (*)
    SET XORDYNAMICS OFF (*)
    SET XORDYNAMICS ON (*)
    SET XORDYNAMICS TOGGLE (*)
    SET XORSLOT
    SHOW
    show acs
    SHOW AE
    SHOW CAMERA
    SHOW CAMERA LENS
    SHOW CAMERA POSITION
    SHOW CAMERA TARGET
    SHOW DEPTH
    SHOW DEPTH ACTIVE
    SHOW DEPTH DISPLAY
    SHOW EOF (*)
    show flag
    SHOW FONT
    SHOW HEADER
    SHOW HEAP (*)
    SHOW KEYINS
    SHOW LIBRARY
    SHOW PATTERN
    SHOW PLOTTER (*)
    SHOW PRINTER
    SHOW REFERENCE
    SHOW SCANNER (*)
    show tolerance
    SHOW UORS
    show views
    show webtags
    show webtags color
    show webtags off
    show webtags on
    show webtags toggle
    sketch
    smartline
    smartline arcbylength
    smartline arcbylength dialog
    smartline join off
    smartline join on
    smartline join toggle
    smartline segment arcs
    smartline segment lines
    smartline segment toggle
    smartline vertex chamfer
    smartline vertex round
    smartline vertex sharp
    smartline vertex toggle
    SNAP
    SNAP ACS
    SNAP ACS OFF
    SNAP ACS ON
    SNAP ACS TOGGLE
    SNAP BISECTOR
    SNAP CENTER
    SNAP INTERSECTION
    SNAP KEYPOINT
    SNAP MIDPOINT
    SNAP MODE (*)
    SNAP NEAREST
    SNAP OFF
    SNAP ON
    SNAP ORIGIN
    snap parallel
    snap perpendicular
    snap pointon
    SNAP PROJECT
    snap pttangent
    snap ptthrough
    snap tangency
    spellcheck editor
    spin
    spin copy
    spin original
    splines settings
    split surface
    spotlight
    spotlight adjust
    spotlight boxfilter
    spotlight cleardatabase
    spotlight defaults
    spotlight environment
    spotlight extents
    spotlight fresnel
    spotlight jitter
    spotlight limitmemory
    spotlight newenv
    spotlight quickdisplay
    spotlight reflections
    spotlight renderallobjects
    spotlight resetdefaults
    spotlight scale
    spotlight set adjust off
    spotlight set adjust on
    spotlight set boxfilter off
    spotlight set boxfilter on
    spotlight set colorclip off
    spotlight set colorclip on
    spotlight set contrast
    spotlight set contribution
    spotlight set environment off
    spotlight set environment on
    spotlight set extents off
    spotlight set extents on
    spotlight set filterheight
    spotlight set filterwidth
    spotlight set fresnel off
    spotlight set fresnel on
    spotlight set jitter off
    spotlight set jitter on
    spotlight set limitmemory off
    spotlight set limitmemory on
    spotlight set maxreflections
    spotlight set maxsamples
    spotlight set maxtransparency
    spotlight set memorylimit
    spotlight set meterspermu
    spotlight set minsamples
    spotlight set quickdisplay off
    spotlight set quickdisplay on
    spotlight set reflections off
    spotlight set reflections on
    spotlight set renderscale off
    spotlight set renderscale on
    spotlight set scalefactor
    spotlight set shadows off
    spotlight set shadows on
    spotlight set statistics off
    spotlight set statistics on
    spotlight set stereo off
    spotlight set stereo on
    spotlight set transparency off
    spotlight set transparency on
    spotlight shadows
    spotlight statistics
    spotlight stereo
    spotlight subdivideallobjects
    spotlight transparency
    START
    stitch surface
    stretch faces
    SUBMENU
    SURFACE
    SURFACE PROJECTION
    SURFACE REVOLUTION
    SWAP
    SWAP SCREEN
    TEXT
    TEXT FAST
    TEXT MODE (*)
    TEXT MODE OFF (*)
    TEXT MODE ON (*)
    TEXT OFF
    TEXT ON
    TEXT SLOW
    TEXT TOGGLE
    THAW
    toggle cube
    toggle mode
    toggle override
    toggle viewbox
    TRANSFORM
    transform install new tools
    transform restore original tools
    TRESET
    TRIM
    trim multi
    trim quick
    trim quick cut
    trim quick extend
    trim quick trim
    trim surface
    trim toolbox
    TYPE
    UCC
    uncut
    UNDO
    UNDO ALL
    UNDO ALL NOCONFIRM
    UNDO MARK
    UNGROUP
    untrim surface
    UPDATE
    UPDATE 1
    UPDATE 2
    UPDATE 3
    UPDATE 4
    UPDATE 5
    UPDATE 6
    UPDATE 7
    UPDATE 8
    UPDATE ALL
    UPDATE BOTH
    UPDATE FENCE
    UPDATE FENCE INSIDE
    UPDATE FILE
    UPDATE GRID
    UPDATE LEFT
    update model
    UPDATE RIGHT
    UPDATE VIEW
    update view extended
    USERCOMMAND
    vba
    vba closemodal
    vba closemodal cancel
    vba closemodal no
    vba closemodal ok
    vba closemodal stop
    vba closemodal yes
    vba create
    vba edit
    vba hide
    vba load
    vba pause
    vba pause recording
    vba resume
    vba resume recording
    vba run
    vba saveall
    vba show
    vba show editor
    vba show macros
    vba start
    vba start recording
    vba stop
    vba stop recording
    vba terminate
    vba unload
    VERSION
    VIEW
    VIEW BACK
    VIEW BOTTOM
    VIEW CLEAR
    VIEW CLIP
    VIEW CLIP ALL
    VIEW CLIP ICON
    VIEW CLIP SINGLE
    VIEW FRONT
    VIEW IMAGE
    VIEW ISO
    VIEW LEFT
    VIEW NEXT
    VIEW OFF
    VIEW OFF 1
    VIEW OFF 2
    VIEW OFF 3
    VIEW OFF 4
    VIEW OFF 5
    VIEW OFF 6
    VIEW OFF 7
    VIEW OFF 8
    VIEW OFF ALL
    VIEW OFF LEFT
    VIEW OFF RIGHT
    VIEW ON
    VIEW ON 1
    VIEW ON 2
    VIEW ON 3
    VIEW ON 4
    VIEW ON 5
    VIEW ON 6
    VIEW ON 7
    VIEW ON 8
    VIEW ON ALL
    VIEW ON LEFT
    VIEW ON RIGHT
    VIEW PREVIOUS
    VIEW RGHTISO
    VIEW RIGHT
    VIEW TOGGLE
    VIEW TOGGLE 1
    VIEW TOGGLE 2
    VIEW TOGGLE 3
    VIEW TOGGLE 4
    VIEW TOGGLE 5
    VIEW TOGGLE 6
    VIEW TOGGLE 7
    VIEW TOGGLE 8
    VIEW TOGGLE ALL
    VIEW TOGGLE LEFT
    VIEW TOGGLE RIGHT
    VIEW TOP
    viewgroup
    viewgroup apply
    viewgroup create
    viewgroup delete
    viewgroup properties update
    vsql
    vsql clearsql
    vsql commit
    vsql create table
    vsql dataset query
    vsql dataset read
    vsql dataset write
    vsql delete
    vsql execute
    vsql forms edit
    vsql forms open
    vsql forms saveas
    vsql highlight fence
    vsql hilite fence
    vsql insert
    vsql joins save
    vsql open
    vsql output
    vsql queries open
    vsql queries save
    vsql queries saveas
    vsql review fence
    vsql rollback
    vsql selection fence
    vsql settings forms
    vsql tables open
    vsql update
    WINDOW
    WINDOW AREA
    window arrange
    WINDOW BACK (*)
    WINDOW BOTTOMTOTOP (*)
    WINDOW CASCADE
    WINDOW CENTER
    WINDOW CHANGESCREEN (*)
    WINDOW CLOSE (*)
    WINDOW FRONT (*)
    WINDOW MAXIMIZE (*)
    WINDOW MINIMIZE (*)
    WINDOW MOVE (*)
    WINDOW MOVE ALLCORNERS (*)
    WINDOW MOVE BLCORNER (*)
    WINDOW MOVE BRCORNER (*)
    WINDOW MOVE BTMEDGE (*)
    WINDOW MOVE LEFTEDGE (*)
    WINDOW MOVE RIGHTEDGE (*)
    WINDOW MOVE TLCORNER (*)
    WINDOW MOVE TOPEDGE (*)
    WINDOW MOVE TRCORNER (*)
    WINDOW ORIGIN
    WINDOW RESTORE (*)
    WINDOW SINK (*)
    WINDOW TILE
    WINDOW VOLUME
    wordprocessor
    wordprocessor dialog open
    wordprocessor edit auto
    wordprocessor edit dialogtext
    wordprocessor edit single
    wordprocessor edit text
    wordprocessor open
    wordprocessor place note dialog
    wordprocessor place note icon
    wordprocessor place note multi
    wordprocessor place text above
    wordprocessor place text along
    wordprocessor place text below
    wordprocessor place text fitted
    wordprocessor place text fvi
    wordprocessor place text icon
    wordprocessor place text on
    wordprocessor place text tmatrix
    wordprocessor place text vi
    wordprocessor place text wordwrap
    WSET
    WSET ADD
    WSET COPY
    WSET DROP
    ZOOM
    zoom 3d
    ZOOM IN
    ZOOM IN CENTER
    zoom in extended
    ZOOM OUT
    ZOOM OUT CENTER
    zoom out extended
    Kirk
    I Wish Cadland was Reality
  • geewizz  couldnt you just have added a zip file I got dizzy trying to scroll down forever!
    Lorys
    click link to PM me
