is there a way to hide the Ribbon permanently?
Right now I have to minimize the ribbon at every start of the program and at every switch to different Model and files.
thanks
Hi Ulrich,
You can use 'Minimize the Ribbon' option just next to Search Ribbon. Check the following link:
https://communities.bentley.com/products/microstation/w/microstation__wiki/39407/how-to-permanently-display-ribbon-tools
You can alternatively double click on any of the tab say, Home or View and the ribbon will be collapsed.
The ribbon will remain minimized when switching between the files or models.
HI Karan,
thanks for answering, I known the "minimize the Ribbon" function .
as I wrote the ribbon pop-up again at every new start of microstation or when I switch thru different models.even when I save my configuration (ctrl+F)
Ulrich Engel said:Right now I have to minimize the ribbon at every start of the program and at every switch to different Model and files.
Ulrich Engel said:is there a way to hide the Ribbon permanently?
please respect the best practices and specify the used version exactly! There have been 16 versions of CONNECT Edition released so far.
Using MicroStation CE U14, I do not see this behavior. Ribbon stays minimized when model / design file / sessions are changed.
With regards,
Jan
Jan Šlegr said:please respect the best practices and specify the used version exactly! There have been 16 versions of CONNECT Edition released so far.
Hi Jan, Sorry.I am using Microstation CE U13 (10.13.00.48)
Ulrich Engel said:I am using Microstation CE U13
That's probably the reason of the issue.
When you check the list of resolved defects for CE Update 14, you can see that #1061144 - Fixed issue with Ribbon status not staying minimized bug was fixed.
