hi
i used to use v8, now i'm upgraded to connect edition. I have Terra Modeler added on it. Now my problem is: In v8, lidar points are displayed below the shaded surface but in connect edition points are displayed over shaded surface. i want the points to go behind the shaded surface. Any ideas? Help would be much appreciated. pls.
lunjal shakya said: I have Terra Modeler
This MicroStation Forum does not specialise in TerraModeler. I suggest that you post your question to a TerraSolid Forum.
