I am a new MicroStation user (Version 10.13.01.01)
Whenever I open a file, I get the message below. How do I set MicroStation to always open with no WorkSet (or another)?
Koog
I believe the following Enhancement is currently being looked at by our software development team. You might like to raise a new Service Request which can be linked to this.
Enhancement 1060165: Request option to select another or no WorkSet on File > Open Mismatch Alert dialog
Answer Verified By: Koog
Shouldn't I be getting a No WorkSpace choice instead of Example WorkSpace? This same WorkSet Alert comes up even if I open MicroStation and select No WorkSpace and New File with no seed file selected. If I hover over the notebook icon, it says, "No active WorkSet". Shouldn't it say WorkSpace?
Still waiting for CAD manager training
Bentley LEARN has several learning paths for CAD management. I believe those are On Demand.
MaryB
We have had this issue since we started using MSCE. A drafter will accidently open one of the metrostation sample files and after that any other file he opens with that same instance of microstation is infected with the metrostation virus. We have tried running batch process to clean our drawings of the virus with "file dissociate workset", but ultimately the solution was to delete the sample workset folders from all microstation workstations and not to install the option on new workstations.
Thansk
Ray J
