I am a new MicroStation user (Version 10.13.01.01)
When I paste from the clipboard, the Scale dialog is not visible. I don't know if it is out of the drawing area or where the setting is to make it show.
The image below shows what I am looking for.
Is the tool setting dialog open for all of the other tools? You can go to the search at the top of your MicroStation and look for Tool Settings
MaryB
MaryB,
If I type "tool settings" into the search ribbon, I don't get any results. I also tried closing and reopening the program and I noticed my Element Selection dialog is off to the left side. I can't move it into the drawing area. See the images below. The other dialogs do not seem to be working either.
Try changing you screen resolution to something like 800 x 600. You may be able to grab the tool setting dialog and pull it back into a Microstation window. Once done save settings and reset your screen resolution. This issue has been on-going since dialogs can reside out side of Microstation windows. It may not work, but it usually my first step.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Answer Verified By: Koog
There is some good advice in this thread: https://communities.bentley.com/products/microstation/f/microstation-forum/99618/toolbox-docking
Generally, speaking dialogs float in MS and you can dock them and Save Settings (Ctrl-F) to save that for the next session.
Samir
mwlong,
That was the answer. I very much appreciate the help.
Koog
