In v8i Illustration mode, all edge lines are intact - but in CONNECT some lines don't display unless I zoom in. This seems to apply to arcs only.
I have Anti-alias lines Off in both cases, and default settings in my Nvidia control panel.
Any ideas why this is happening?
CE 10.14.109
Hi Max, would it be possible to share the file (or part of it) so that our support team can try to reproduce? What video card driver version are you using?
Thanks Marco - file attached (I've cleared out a lot of data, but the problem persists).
Nividia Quadro M4000, resolution 3840x2160
Driver version 442.50
Illustration.dgn
I can confirm that this happens on other machines too, so I don't think its a hardware problem.
The problem exists also on my computer with Radeon RX 5700, so it's not Nvidia card dependent.
Jan
Hi All,
thanks for testing this. I have filed Defect 1102173 against this issue.
R,
Marco
