MS V8i SS3 Item Sets display problem
Hello All,
I'd like to hide some elements in attached files which is not in same level, the only way I know is to add them into an item sets and then set display off on this item sets.(Please let me know if any other way.)
It works fine with display styles which render mode is Wireframe or Shaded.
But it doesn't work with display styles which render mode is Visible Edges or Filled Visible Edges.
Is it a bug? Or how can I fix it? We need the display style Hidden Line(Visible Edges). Thanks a lot.
Parents Reply Children
