PokeIt for MicroStation — Select and View Elements Based on Attributes FROM Elements, Plus Much More
PokeIt is a MicroStation VBA application. It's used to select, isolate or hide elements based on their attributes, such as level, color, line style, etc. The filter criterion is populated from a selected, or "poked," element rather than from a list in a dialog box.
PokeIt is also used to create elements similar to a selected element.
There are also a couple of additional “bonus” commands, Invert Selection and Fence Subset.
The interface of PokeIt is the context menu, accessed with a right press and hold on an element..
Here's a link to a short video of PokeIt in action: https://youtu.be/zKQDIH7RzBs
Note: Installation instructions are in the included PDF file.
Compatible with MicroStation Connect Edition1104.PokeIt v6.zip
Compatible with MicroStation V8i0434.PokeIt v5.zip
