PokeIt is a MicroStation VBA application. It's used to select, isolate or hide elements based on their attributes, such as level, color, line style, etc. The filter criterion is populated from a selected, or "poked," element rather than from a list in a dialog box.
PokeIt is also used to create elements similar to a selected element.
There are also a couple of additional “bonus” commands, Invert Selection and Fence Subset.
The interface of PokeIt is the context menu, accessed with a right press and hold on an element..
Here's a link to a short video of PokeIt in action: https://youtu.be/zKQDIH7RzBs
Most recent update: PokeIt v7.3.zip
Note: Installation instructions are in the included PDF file.
Compatible with MicroStation Connect Edition: 1104.PokeIt v6.zip
Compatible with MicroStation V8i: 0434.PokeIt v5.zip
Place the MVBA file in a folder pointed to by the MS_VBASEARCHDIRECTORIES configuration variable.
Tim. Daft question but where do I need to locate these files do that user can use Pokeit?
Stuart
Because you have a customised Workspace, it is easier if you look for the paths for the following 2 variables and copy the 2 files from the zip file to the corresponding folder.
MS_GUIDGNLIBLIST
HTH
Ian
Tim
I have tried the Hide option on a new file with simple shapes and it works OK. However, it struggles with complex data in a reference file. So are reference files elements supported by your app.
It seems to go through the motions but then selects something different and nothing hides
Ian Lapper said:Because you have a customised Workspace, it is easier if you look for the paths for the following 2 variables and copy the 2 files from the zip file to the corresponding folder. MS_GUIDGNLIBLIST MS_VBASEARCHDIRECTORIES
Thanks.
