I would like to know the keyin (if there is one) to toggle a model space from Sheet to Design in Microstation CE. I have tried recording a macro to see what is recorded in both bentley and vba modes but nothing shows.
I don't want to go down the route of complicating it with vba, all I am looking for is a keyin so that I can splice it into a batch process series of commands....
Thanks in advance for your help.
Hi Ted
Been a while. hope all is OK .
To do this you need to knwo the names of the Models ie default and sheet.
Then you can use the keyin... model active "sheet" or model active "default"
I would suggest you place this on a Fkey or an icon
HTH
Ian
Hi Ian, good to hear from you,
I wasn't looking to swap out a model for a named model, I was looking to change the model TYPE from Sheet to Design.
Hi Ted.
I have had a look and I cannot see an easy (keyin) way to do this.
How many files do you need to process?
Not to worry, I will find another way. Bit strange there is not keyin or named command built in by Bentley for this though!
Thanks for your help Ian
Best, Ted
Ted
Many of the dialog boxes do not have specific keyins to define or change these items. This specific question was asked on the following discussion of which Leonard Jones provided a sample VBA to perform this operation.
https://communities.bentley.com/products/microstation/f/microstation-forum/148472/sheet-to-design-model-key-in
