Hi everyone,I report a request that was made to me:In Microstation Connect it's possible create a plane figure (Shape, ComplexShape), using the GroupedHoles function, where the resulting plane figure is presented with a "hole" inside it, but without using multiple elements (eg shape with another shape inside) so that Microstation sees it as the unique Shape or ComplexShape element?
best regards,
Salvio
Hi Salvio,
as others, I would ask to provide more details what you want to achieve, because it's not very clear.
Moreover, several different terms are used and mixed in your text.
salvatore montella said:In Microstation Connect it's possible create a plane figure
What MicroStation offers is based on topology rules and elements provided by DGN V8 format. It's important (but maybe confusing sometimes) to distinguish between "MicroStation elements" presented in GUI and "DGN V8 elements" how data is stored ;-)
salvatore montella said:the resulting plane figure is presented with a "hole" inside it, but without using multiple elements (eg shape with another shape inside)
Sorry, but it's nonsense, because when there is a boundary and a hole, they are always two elements. How this situation can be modeled using one element only?
What you are talking about is close to a concept of "a collection of elements", which is exactly what cell is in MicroStation, and consequently what GroupedHoles tool does: It encapsulate the elements (closed elements defining boundary and holes) into a collection (cell).
salvatore montella said:so that Microstation sees it as the unique Shape or ComplexShape element?
No, because Shape and Complex shape elements defined as closed elements, defined by one topology only.
With regards,
Jan
