hello all,
I'm using Microstation V8i SelectSeries 10 version 08.11.09.919.
I attached a jpg file in a series of dgn file, adjusted the scale and position, saved, and printed each of them yesterday. Everything looked fine. However, today when I opened these file and tried to do more editing, the jpg file I attached in each dgn file is moved far far away from it was yesterday.
What might be the reason? What should I do to fix it where it is supposed to be?
Best regards
According to one of my testing machines, the similar issue was observed (e.g. the MicroStation grid lines in view window were moving by themselves). It may not be related to your case. But I would like to share how I could fix from my end. The issue was the 3DCONNEXION device' software did make abnormal operation. After removing the software, everything turned out to be normal. Upgrading the latest software also fixed the issue.
Hyung
