CONNECT R14 update Setup error: failed to plan installation with error code 2147024809
I attempted to install CONNECT R14 update to a Windows 10 installation which already has a V8i SS10 installation. The first attempt to run setup resulted in a window saying that the setup was initialising which I had to kill after a few hours. Then I uninstalled and reinstalled which indicated success. However when launching MicroStation it immediately crashes with no additional information. When I try the option to repair the installation it gives me the message "failed to plan installation with error code 2147024809".
I hereby attach the log file.
MicroStation_CONNECT_Edition_20200721161511.log
Any help would be appreciated.
Kind regards,
Mark Smit
NedGraphics
