MicroStation will not package ACAD verision higher than 2016, is this true?
Hi Carl,
Carl Jones said:MicroStation will not package ACAD verision higher than 2016
If by "package" you mean compatibility, then it depends on the version of MicroStation you are using.
The latest MicroStation CONNECT Edition Update 14 supports AutoCAD 2018/2019
Attaching the computability matrix for your reference:
https://communities.bentley.com/products/microstation/w/microstation__wiki/26644/which-microstation-version-supports-which-dwg-dxf-version-formats
Carl Jones said:MicroStation will not package open ACAD DWG version higher than 2016
Asking about DWG compatibility without revealing the version of MicroStation you are using likely to be fruitless. Please state your version of MicroStation when you post a question.
The matrix provided by Karan Sharma's link should help you.
