I recently updated my Microstation. Is there a way I can have the "Main", the "3D" and the "Snap Mode" palettes to arrange around my screen. I never used this set of ribbons and it is just a series of more clicks than I need for the work I want to do.
Hi Jason,
It's always good to mention the exact version of MicroStation you are using so that we can suggest you accordingly, check Community Best Practices: https://communities.bentley.com/products/microstation/f/microstation-forum/87312/read-first-microstation-forum-best-practices
If you are on the latest version of MicroStation CONNECT which is Update 14, the following link might be helpful to get task theme similar to V8i either in the form of Dialog or Toolbox.
https://communities.bentley.com/products/microstation/b/microstation_blog/posts/new-in-microstation-connect-edition-update-14---access-v8i-task-theme-from-quick-access-toolbar
To dock the "Snap Mode", go to File > Settings > User > Tool Boxes and check mark the "Snap Mode" option.
Jason for Snaps i use the v8i task theme, but for snaps and anything else you want to dock if you click File > Settings > Tool boxes you can dock any tools you want around the screen.
Thank you Karan. It is Connect 14 as you guessed. Your input was so good. I wonder if there is a way to change that "ribbon' theme there on top. It takes too much space and I so much prefer the traditional menu I used to use since SE.
How do I activate the v8i task theme Grant?
Answer Verified By: Jason Charalambides
